Vinyl Film instead of paint job
Thanks for the thoughts guys.
I might try doing it in sections. Lower then upper, in case I am not thrilled with it. I am looking at a carbon fiber pattern. I checked out youtube for install hints and there was a wealth of information. If it is not perfect, so what, any color is better than the maroon red.
I will show before and after pics if and when.
Thanks again guys.
Thanks again guys.
You'e in the minority since most of these cheap jobs look like ass after a year or two but you also live in Cali where the climate is a little more stable with minimal temperature extremes or actual 4 seasons.
Good paint isn't cheap especially on newer cars but an older vehicle it might do the trick.
The material used for vehicle wraps is more expensive than regular vinyl. Most of the ones we do range from $3000-$5000. Of coarse that includes artwork and a print. Even still the material cost to wrap a truck would be $700-$1000, plus you would need someone to install it. Paint would be cheaper.
#25
I did the rustolum roll on and it cost around 80$ to 90$ for 3 small cans of blue paint primer and the brushes it took 4 days the first 2 coats I thinned out and they did not coat well I would have had to put 10 coats on for a good solid paint job.
I will try the interlux next time if you get the paint on thick enough you can wet sand it down to a very smooth finish and it will buff out real nice with a good wax and a power buffer.
also the primer is not needed if it is not bard metal you are painting on I found the rustolum chipped in a few spots and the primer stayed in place but the blue paint did not bond to the primer well.
#26
hey yeah i love your truck if it was a pre runner with long travel id buy it for sure!!!!! but still would u like to sell it for a reasonable offer?? if so tell me what u want but if not id like to ask u about it sounds soo sick bro bad ass
#28
This may be the only time to post a jeep and not get hammered. I did this wrap a few years ago. It was a 3M wrap that came in 3x4 sheets, and installed dry.I would save up for paint wraps are $$$. Also not super easy
86 87 4Runners
09-05-2015 06:02 AM
86 87 4Runners
09-02-2015 03:54 AM
