Very Bad Gas Mileage
Old 11-01-2011, 05:34 PM
CapnD46Eng's Avatar
Hello Gents.
New to the site and was just wondering if anyone had suggestions about my 89' truck (22re) getting bad gas mileage? I commute to Baltimore and trying to find an economical solution other than replacing it (115,000 original miles). Any solutions are helpful and thanks in advance!
Old 11-01-2011, 06:32 PM
bobby_duce's Avatar
welcome to yotatech! i figured id chime in. 115k is very low for a 22re any idea on the previous maintenance? baring any neglect with the engine id just do a simple tune up and see what happens. whats your mpg currently? also having bigger tires will kill your mileage too.
Old 11-01-2011, 06:50 PM
CapnD46Eng's Avatar
Thanks for the welcome! I picked it up 10 years ago with 28,000 original miles on it from an older gentleman who didn't want to have the truck and his Avalon anymore. The only thing i did to it was put some alloy wheels, went up a tire size to 235X15 and put a pioneer deck in it. Far as maintenance, I replaced the crankshaft seal about 7 years ago and now that you mention it, a tune up about 6 years ago. Not sure of the actual mileage that I'm getting but it is pretty bad (since most of my driving is on the highway).
Old 11-01-2011, 06:53 PM
CapnD46Eng's Avatar
Oh yeah! I'm about to do the front seal again (after market and I didn't replace the oil pump 'O' ring seal when I did the repair)!
Old 11-01-2011, 07:19 PM
toyospearo's Avatar
those things are not going to affect your gas milage.
You should be getting around 22 to 25 mpg on the highway maybe more with the tire size you have.
I would do a full tune up - plugs, plug wires (from the dealer), cap and rotor (from the dealer), adjust the valves, reset the timing change oil and filter THEN see how it goes.
Old 11-01-2011, 08:28 PM
Fossilized
Staff
dropzone's Avatar
Fuel filter wouldn't hurt either
Old 11-02-2011, 03:38 AM
TNRabbit's Avatar
The most common reason for bad fuel mileage is O2 sensor needs replacing. It needs replacing anyway, so do that (Denso or NTK ONLY) & see what happens.
Old 11-02-2011, 07:32 AM
VegasNaturist's Avatar
One Other Suggestion
...I have based on experience is to check your fuel pressure regulator. It uses vaccum (as well as spring pressure) to open and close. If the diaphram is starting to leak, you can suck raw fuel through the vaccum hose.
John
Old 11-02-2011, 08:22 AM
1990yota-pickup's Avatar
just goggle up you tube you can see how to test your o2 sensor pretty easily....
Old 11-03-2011, 05:54 PM
CapnD46Eng's Avatar
O2 sensor, I forgot all about that! Will replace along with the tune up. Thanks Gents! I'll keep you posted!
Charecter1
11-06-2023 10:08 AM
Eggslinger
06-08-2019 03:32 PM
shisha1999
09-21-2015 08:22 PM
pyramid
07-30-2015 10:05 AM
daddio
07-18-2015 10:20 AM
Quick Reply: Very Bad Gas Mileage
