smoke on decel, oil in intake 22re 4runner
Old 08-21-2012, 09:29 AM
Raghorn61's Avatar
I have been seeing smoke on decel, and i pulled my upper intake off and found a puddle of oil in the #4 and #3 intake runner more so in the number 4 wondering were i should look first or if anyone else has seen this problem.
Old 08-21-2012, 10:24 AM
BMcEL's Avatar
There were some responses in your other two identical threads.
https://www.yotatech.com/forums/f116...ration-235051/
https://www.yotatech.com/forums/f116...ration-242377/
Old 08-21-2012, 11:16 AM
Raghorn61's Avatar
I complety blocked off my PCV system from my intake after cleaning my intake and it still is smoking on decel so oil must still be getting in it
Old 08-21-2012, 11:47 AM
snobdds's Avatar
Well of course it is...through the rings and or maybe the valve seats. It's called blow-by and it is an indication of worn piston rings.
Do a compression check and leak down test...Then you know for sure.
Old 08-21-2012, 06:08 PM
TrikeKid's Avatar
Hook your PCV back up and make it function correctly would be a start to fixing your truck. What steps did you go through to break this engine in? Sounds like the rings haven't seated to me.
Old 08-21-2012, 08:03 PM
Raghorn61's Avatar
got 145 psi on all cylinders on a leak down and 5 to 7 % loss on leak down test on each cylinder, i just blocked the PCV off to rule it out because a majority of the oil was under the pcv valve inlet into the upper intake, ther was lots of oil residue in the the tube.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: smoke on decel, oil in intake 22re 4runner
