Rear Defogger Not Working. PLEASE HELP!
Old 01-14-2007, 09:24 AM
keithguts's Avatar
While driving this morning, My rear window im my 1995 4 runner got all fogged up and could not see a thing out of it. I turned on the rear window defogger switch, and nothing. After comming back home, I had noticed a plug in my passenger side rear window was unpluged. I was led to belive that this plug was for an antenner or some sort. My question is, could this be the plug for my rear window defogger. Please help. The switch does light up when I turn it on. If this plug is not for my defogger, where would I look next. Does it have a fuse of any type. I'm thinking that being the switch lights up, the fuse is good, but my not be the case. Any help please.
Old 01-14-2007, 09:28 AM
tc
tc's Avatar
Nope - it's all built in the tailgate. (That plug is indeed for the second antenna)
Most of the time it's the switch. There's a ton of info on here - do a search on "rear window defroster".
Old 01-14-2007, 09:41 AM
91_4x4runner's Avatar
If you have the problem before you can get it fixed, just roll down your back window and roll it back up. The weather stripping usually takes off the condensation.
Old 01-14-2007, 09:42 AM
keithguts's Avatar
I hguess my next question is then, What do I look for next, and is there a fuse for it.
Old 01-14-2007, 06:56 PM
itsmeagain5789's Avatar
yea, myne has the same problem, but eric is right, just roll down the window and it goes away, much easier than looking for the problem
edit: oh yea, and if u find the problem, post it, cause i would be interested in fixing it if its a simple fuse or something, i just havent had enough time to do anything lately.
Old 01-14-2007, 07:25 PM
tc
tc's Avatar
http://www.the-roo.com/4runner/Body_...l/backdoor.pdf
Old 01-15-2007, 04:18 AM
AH64ID's Avatar
my plug at the glass came off, simple fix...
Old 01-15-2007, 11:10 AM
tc
tc's Avatar
So has mine.
Not simple fix - somehow the plugs came unsoldered from the traces...
Old 01-15-2007, 11:22 AM
19RUNNER86's Avatar
carquest has a tab repair kit for like 10 bucks. simple fix...
Old 03-21-2011, 06:59 PM
banoobee17's Avatar
my defog has worked on my 93 4runner ever since i bought two years ago, but recently it has stopped working the light on the switch dont even come on i am gonna check my rear window today but if it is connected could it be the switch itself? and how many fuses are there for it and where? too. please help
Doug4320
03-24-2018 10:11 PM
ghostmoney
01-28-2018 11:42 AM
icentropy
07-14-2015 10:23 AM
KBar
07-13-2015 06:01 PM
88yodabasket
07-13-2015 01:32 PM
Quick Reply: Rear Defogger Not Working. PLEASE HELP!
