Overheating diagnosis
Old 10-20-2009, 10:22 AM
kungfumedia's Avatar
Need help diagnosing problem with my 91 4runner v6, Started rough this morning, put it in drive and it died, died a few more times, finally got it running went about 3 blocks and the heat gauge was maxed out, got it back home and all sorts of steam was coming out of the overflow. No leak as far as I can tell, no puddle/trail. Lots of steam/smoke? out the exhaust on the 4th time starting it, went away quick. Also started idling rough a few days ago. Any ideas? Is this the right section for question like this?
Thanks-
Old 10-20-2009, 11:03 AM
tj884Rdlx's Avatar
1. is there coolant in the rad?
if rough idle started a few days ago, and now you have white smoke, sounds like HG failure. a "block test" will test for leaks at HG.
also, check under oil cap for white goo inside it. check coolant for oil contamination. check dipstick for white goo.
Old 10-20-2009, 11:46 AM
Jason4X4's Avatar
could be w/p froze up, now not pumping water.
Old 10-20-2009, 11:50 AM
totally a bro
Staff
vital22re's Avatar
headgasket, leakin coolant into cylinders
Old 10-20-2009, 12:23 PM
overheating diagnosis
Oil cap is full of white goop, anyone have this fixed before? Any idea on cost to take it in to a shop? Possible reasons on why this happened?
Thanks-
Old 10-20-2009, 12:54 PM
Outsane's Avatar
https://www.yotatech.com/forums/f116...thread-188472/
and here
https://www.yotatech.com/forums/f116...e-help-178123/
Old 10-20-2009, 02:57 PM
tj884Rdlx's Avatar
Thanks-
hg's will fail in time. Cost depends on damage done at time of overheat. Aluminum heads, and every piece of metal that attaches to the motor with a gasket between it should be checked for warping, and resurfaced or replaced. Good luck bro, it's not cheap, but if you can tear down n rebuild yourself you can save a grand in labor. The instructions and support todo it is within this site.
good luckm we're all counting on you
ladybugRC
458
08-21-2020 10:41 AM
alexcarey
10-14-2015 06:05 PM
voiddweller
09-28-2015 11:21 PM
matt1833
09-16-2015 07:11 AM
LotOMiles
09-14-2015 11:45 PM
Quick Reply: Overheating diagnosis
