LSPV Removal
Old 11-30-2006, 06:13 AM
neoworm0's Avatar
LSPV Removal
Well I removed my ABS system this week and thought while I was tearing stuff out of my truck I might as well get rid of the LSPV while I'm at it.
Here is the rusty POS I started with:
[IMG][/IMG]
[IMG][/IMG]
LSPV removed:
[/IMG]
Old 11-30-2006, 06:17 AM
neoworm0's Avatar
Removed the fluid return line first. This line just returns fluid to the front brakes and won't be needed anymore. It is the bottom line going into the LSPV and this connection on the "T" inside the passenger fenderwell:
[IMG][/IMG]
Old 11-30-2006, 06:21 AM
neoworm0's Avatar
Going to replace the LSPV with this:
[IMG][/IMG]
It's a Wilwood manual adjustable proportioning valve. Adjustable from 100 - 1000 psi. Fully open it allows 100% brake pressure to the rear brakes and fully closed reduces brake pressure by up to 57%. Or so says the propaganda.
I decided to place it in the same location as the original PV, however you could put it in line of the rear brake line anywhere you want. I think most people like to put it under the hood just after the MC (Master Cylinder) however my truck isn't a DD and stays pretty clean so I think it will be fine there. I can access the knob easily through the wheel well and it was the least amount of work to put it there. I removed the mounting bracket from the LSPV and used it to mount the Wilwood.
[/IMG]
One note: The Wilwood came with fittings that accepted SAE flare nuts not metric. I wasn't able to locate any metric to SAE adapters so I had to cut the metric flare nut off the Toyota line that runs from the MC and flare a new nut on. For the hard line that runs from the PV to the SS flex line I just made up a new line with one SAE end and one Metric end.
Old 11-30-2006, 06:38 AM
neoworm0's Avatar
Once that was done I needed to plug the "T" in the fenderwell where the return line was connected. Again I couldn't find a 10mm - 1.0 plug.
I did find an adapter with a metric male and SAE female though so I used that and added a 3/16 plug to it. It's kind of ghetto but It will do for now until I can locate a metric plug.
[IMG][/IMG]
Old 11-30-2006, 06:48 AM
neoworm0's Avatar
Lastly I ground off the tab that the arm pivot was attached too.
Before:
[IMG][/IMG]
After:
[IMG][/IMG]
Old 11-30-2006, 06:52 AM
neoworm0's Avatar
The finished product:
Before:
[IMG][/IMG]
and After:
[IMG][/IMG]
Old 11-30-2006, 07:01 AM
4Crawler's Avatar
I have M10x1.0 male and female brake line plugs available. They run $12.00/ea.:
Old 11-30-2006, 07:10 AM
waskillywabbit's Avatar
The plugs Roger shows above work obviously, but I too could not find any when I did my rear disc swap...so I took the old 10mm fitting that did go to that tee and soldered/welded up the end of it.
Old 11-30-2006, 08:30 AM
neoworm0's Avatar
I thought of doing that as well but I figured there had to be a metric plug available somewhere.
Those look good Roger, but my current setup cost $0.73 CDN. As much as I don't really like it I think I'll get used to it. Meanwhile I'll keep looking locally. Thank you though.
1uzRunner
63
11-10-2018 03:58 PM
Anthony Lee Mathis
09-15-2015 07:22 AM
Rickstwowheels
09-09-2015 06:12 PM
gp66
09-07-2015 08:29 AM
Aaron Logan
09-03-2015 08:08 AM
Quick Reply: LSPV Removal
