Headlight Brights don't work with switch - advice?
Old 03-24-2015, 04:19 PM
seattlecard's Avatar
Hi all -
I have a 94 SR5 4runner and am having the following issue:
Headlights work in low beam, but when I switch to brights, the headlights shut off.
Now, interestingly, if I use the hi-beam "flash" mode (pulling the handle toward me) the brights indeed DO come on. They just wont stay on when I switch it to stay.
Anyone have any clues?
Thanks!
Old 03-24-2015, 04:52 PM
RAD4Runner's Avatar
Bad High-Beam contacts of your headlight dimmer-combo switch.
After you fix this, I suggest you do the H4 conversion harness, to fix the retarded stock wiring that leads to death of dimmer-combo switch contacts.
Old 03-24-2015, 08:06 PM
Shady Cadence's Avatar
Please elaborate on this, as I have the same issue in the same truck.
Old 03-24-2015, 08:14 PM
Thank you - I found this link as a starting point: http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Old 03-24-2015, 08:27 PM
RAD4Runner's Avatar
On Stock circuit:
  • Wires are thin (AWG 18/20?)
  • Ground circuit goes from bulbs, to cabin, to dash to dimmer switch, back to engine compartment to ground inside passenger-side fender (exactly a convoluted path as 4Crawler describes it), causing a lot of resistance, a lot of voltage drops and reducing voltage that actually reaches the bulbs.
  • Dimmer (combo) stalk switch contacts carry high current (10 Amps on 60-watt high beam, 17 Amps on 100-watt high beams). This will shorten contact life.
H4 Harness retrofit will fix this.
Old 03-24-2015, 08:41 PM
Thank you. I had considered doing this when I priced a combo switch. Figure I'll just fab the harness a little differently to minimize costs. I'm beyond broke right now.
Old 03-24-2015, 08:50 PM
On Stock circuit:
When I pulled the schematic to figure out the light issue I looked at it and just knew the current had fried the contacts, couldn't understand why they would wire it this way. Had planned on adding relays and re-working the wiring, but didn't figure you could dismantle the switch and fix it. SO going this route.
I knew of the circuit issues, just had never heard of "the H4 conversion" before.
Old 03-24-2015, 10:11 PM
RAD4Runner's Avatar
If you're comfortable with a little rewiring and wanna minimize cost, you can try my method. Only required ONE relay and some wire.
I rewired this way.
Basically, stock control circuit is used to control relay. Relay contacts took the place of dimmer switch contacts.
Old 03-24-2015, 11:52 PM
wyoming9's Avatar
Red face
Was this issue ever fixed in the newer models??
If so what year or does it still continue in the 2015 models ??
I have yet to have any problems on any of the fleet.
I guess to many other maintenance items need attention .
To many projects not enough hands
Old 03-25-2015, 12:01 AM
RAD4Runner's Avatar
They probably have fixed it in newer models. However, I haven't seen schematic yet.
I have yet to have any problems on any of the fleet. New fleet or old Yotas
Well... it's partly because Yota parts are made so robust, they withstand abuse, so we do not notice the problem on most trucks.
LOL! Yep! I'm currently unemployed but I still can't seem to find enough time to work on my truck- just lots of little details to fine tune here and there... rattles, etc. Nothing to keep me for daily driving or even road trips.
Old 03-25-2015, 06:22 AM
bswarm's Avatar
You can find the wiring harness kit on eBay for around $25, and the H4 kit for about $85. There's a thread about this at https://www.yotatech.com/forums/f131...w-pics-235789/ You will lose the high beam indicator with the new harness. The headlamp difference is like night and day, well worth the money.
Old 03-25-2015, 12:14 PM
I rewired this way.
Love it! I WILL be going that route, even scrounged a relay out of the magic tool box drawer.
Did you ever wire up the HBI lamp?
Old 03-25-2015, 01:31 PM
RAD4Runner's Avatar
Not yet. Havent had the chance to dig into wiring to modify. Stock config is also retarded. Uses LB to shunt across HBI lamp to keep it off, meaning current thru LB lamp still flows thru the LB switch contacts. I may just connect a current-limiting resistor from that positive side of HBI section to load side of stock headlights relay (as high a resistance as possible that wud still light up the HBI).
Old 03-28-2015, 09:47 AM
Staff
Terrys87's Avatar
Here is how I fix mine without replacing the combo switch https://www.yotatech.com/forums/f199...l#post51724567
gillesdetrail
11-19-2019 12:56 PM
Yota.Jay
03-06-2016 11:02 PM
bigblue82
10
07-06-2015 08:27 AM
aciorba23
06-29-2015 04:18 PM
gog1968
06-22-2015 05:55 AM
Quick Reply: Headlight Brights don't work with switch - advice?
