Changed knock wire won't run!
Old 04-23-2009, 07:31 PM
guntee1's Avatar
Please help me boys Changed knock sensor wire in my 91 truck 3zve and now it won't run it rolls about ten times fires and quits within seconds. Checked fuel pump, wires, conections three nights of insanity before i remembered this site wich helped me with my engine change last year thank you for that! so any help would be appreciated
Old 04-23-2009, 07:45 PM
toyota4x4907's Avatar
any CEL codes?
Old 04-23-2009, 07:52 PM
Kiroshu's Avatar
did you put it back together right.... sounds like maybe when you did that you may have forgotten or messed up the intake manifold gaskets..... if they are leaking it does this.... all lines hooked up.... wires in right places.....? Check engine light? If so get codes....
Old 04-23-2009, 11:46 PM
TNRabbit's Avatar
You DO have the VAFM back in place & plugged in, RIGHT?
Old 04-24-2009, 03:06 PM
scope103's Avatar
Losing the knock sensor will throw a code, but I don't think it will prevent you from starting.
As TNRabbit hints: you need to take a deep breath and think systematically. Fuel, air, spark: what are you missing?
Old 04-24-2009, 06:55 PM
guntee1's Avatar
what is the VAFM and where is it located? Gaskets should be good only go on one way?
Old 04-24-2009, 06:57 PM
guntee1's Avatar
can you get codes if it has not ran for more than a few seconds?
Old 04-24-2009, 07:06 PM
RMA
RMA's Avatar
Can you take some pictures of the engine compartment and post them here.
Maybe 3 or 4 from diffrent angles.
Maybe we might be able to see something wrong, just maybe.
Old 04-26-2009, 08:02 AM
guntee1's Avatar
get back to you
Old 04-26-2009, 02:48 PM
guntee1's Avatar
still trying go again tomorow
Old 04-27-2009, 04:00 PM
guntee1's Avatar
Changed intake and messed with timing finally got it with no engine codes wa ho! thanks everybody!
JF9243176
10-08-2017 04:21 AM
serenity03k64
06-27-2015 07:59 AM
newzingo
06-24-2015 01:50 PM
JF9243176
06-24-2015 04:53 AM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: Changed knock wire won't run!
