91 4x4 22re timing chain help
Old 06-15-2006, 04:06 PM
JRodsrunner95's Avatar
a friend has a 91 4x4 22re and the guide broke on his timing chain and it slipped time, im not sure about how to set the time and is there anything else that i need to check or do, in result of it slipping time..
please help
jared
Old 06-15-2006, 04:24 PM
Elton's Avatar
did you search ?
Old 06-15-2006, 06:03 PM
AKennedy87's Avatar
There are lil notches on the gears, just make sure at TDC the dots are both directly in the middle, then it is set.
Old 06-16-2006, 05:21 PM
thanks for the reply it helped alot
jared
Old 06-16-2006, 05:46 PM
ovrrdrive's Avatar
Dude... If it jumped you need to get a new timing set and replace the gears, tensioner, guides and chain. There's a reason it slipped and now that it has slipped the chain probably stretched even more.
What happened to mine was the plastic chain guide broke and went through the bottom gear which jumped the time, cracked the timing cover, and bent all 4 intake valves.
Why did it jump?
Is the drivers side plastic rail broken?
Did you check the compression?
How long do you want this repair to last?
Old 06-16-2006, 06:57 PM
crackerjack's Avatar
I haven't looked under the hood of any other yota's do they have problem with oil leaking around timing chain housing? It kinda buggin me and I'm considering pulling housing and really tring to get a good seal so I'll have a dry engine ps all new LC timing upgrade,two machanics told me toys are known for this oil leak?
Old 06-16-2006, 10:44 PM
Brendan's Avatar
mine has a bit of a leak around the timing cover. not enough to make me want to tear it all apart again though.
Old 06-17-2006, 08:35 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
So did mine. I have an '86 4rnr. Used auto-rx and leak stopped. If you've never used it, you might give it a shot.
Old 06-17-2006, 03:43 PM
yeah I know I'm being picky I'm gonna get one of those electric fans my shroud is bad pulling the radiator will give me a chance to just pull cover and reapply sealant. ps Summitracing has the best price on a good e fan I've found
Ichneumon
09-27-2015 04:21 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 91 4x4 22re timing chain help
