91 4x4 22re timing chain help
a friend has a 91 4x4 22re and the guide broke on his timing chain and it slipped time, im not sure about how to set the time and is there anything else that i need to check or do, in result of it slipping time..
please help
jared
please help
jared
Dude... If it jumped you need to get a new timing set and replace the gears, tensioner, guides and chain. There's a reason it slipped and now that it has slipped the chain probably stretched even more.
What happened to mine was the plastic chain guide broke and went through the bottom gear which jumped the time, cracked the timing cover, and bent all 4 intake valves.
Why did it jump?
Is the drivers side plastic rail broken?
Did you check the compression?
How long do you want this repair to last?
Why did it jump?
I haven't looked under the hood of any other yota's do they have problem with oil leaking around timing chain housing? It kinda buggin me and I'm considering pulling housing and really tring to get a good seal so I'll have a dry engine ps all new LC timing upgrade,two machanics told me toys are known for this oil leak?
yeah I know I'm being picky I'm gonna get one of those electric fans my shroud is bad pulling the radiator will give me a chance to just pull cover and reapply sealant. ps Summitracing has the best price on a good e fan I've found
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
