88 4 Runner - Clutch Help / Advice
Old 09-18-2006, 09:56 PM
gwhite's Avatar
Hi. Any advice would be greatly appreciated.
I have a 88 4runner and have run into some trouble. The clutch is completly soft, there is no tension on at all. There is a leak in the clutch fluid line and I think that there might be a airlock in the line now if the clutch had been dry and driven for a bit.
My question is. Could it be either the airlock or maybe a spring problem ? If so, is it easy to bleed the clutch line or fix the spring. Any help would be really appreciated. Thanks
Garth
Old 09-19-2006, 06:04 AM
shredder's Avatar
Sounds like the Clutch Slave Cylinder,
This is very common for the slave cylinder to go out .
It is a easy fix and cost about $20 .
Old 09-19-2006, 07:26 AM
dcg9381's Avatar
Just FYI, I haven't had good luck with aftermarket slave and MCs... I've also seen master cyl go after replacing the slave.
If there is a leak in the line, you need to fix that before doing anything else.
You bleed the clutch just like the brake system to get the air out.
Old 09-19-2006, 10:40 AM
MMA_Alex's Avatar
yep, bleed the clutch. if its a leak then replace whatevers leaking, and bleed it. It bleeds just like brakes do, but some people use little tricks to get air out easier.
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 88 4 Runner - Clutch Help / Advice
