1988 4 runner NEW oil leak
Old 04-11-2006, 06:57 AM
Steve 1stgen's Avatar
To all,
My 1988 4Runner stalled out in a parking lot and started to leak oil (alot). The engine has been resealed, (value cover, oil pan, etc) and there have been no oil leaks for a year. I waited a day and the started the engine with no knocks or grinding, so I didn't throw a rod through the engine block. I haven't taken apart the truck yet but the leak looks to be coming from the front of the truck of the engine block, that is where all the oil is all over the front. Any ideas?
Thanks,
Steve
Old 04-11-2006, 07:59 AM
Flash319's Avatar
I would say front crank oil seal.
Old 04-11-2006, 08:57 AM
EWAYota's Avatar
Could be the oil pump seal, or timing chain cover.
Old 04-11-2006, 09:50 AM
YotaJunky's Avatar
Clean off the surface oil and see if you can detect where the leak is coming from. I'm also guessing that it's the front main seal.
Troy
Old 04-11-2006, 09:52 AM
kyle_22r's Avatar
fortunately the front main seal is easy to replace. remove the fan shroud, belts and crank pulley, then unbolt the oil pump. knock the seal out of it, then drive a new one in and reassemble. i'd recommend using a new oil pump o-ring as well.
now, a rear main seal, those aren't fun in the least. after you've done 2 in as many weeks, you start to not like working on cars...
Old 04-11-2006, 04:25 PM
Hmm... I had the timing belt replaced in October and all the other stuff that goes with it (original water pump, seals, original radiator, etc.). Since the equipment was all original, I spent the money to have an new front end, so to to speak. I will be @#$%*$ if I got a bad seal somewhere in that process.
duckhead
170
11-13-2017 06:07 AM
JF9243176
10-08-2017 04:21 AM
voiddweller
19
05-02-2016 09:10 PM
ian1386
07-01-2015 11:23 AM
JF9243176
06-24-2015 04:53 AM
Quick Reply: 1988 4 runner NEW oil leak
