Power Window Question
I recently purchased an 84 4 runner. The PO said that the windows were dead and would have to be replaced. After getting the FSM for an '85 I figured out the little breaker in the kick panel by the fuses. My problem is now I can roll my driverside window up and down and i can roll my passenger side window down but not up. Does any one know what else would cause this.
Thanks
Adam
Thanks
Adam
Thanks
Adam
Thanks
Adam
- http://www.4crawler.com/4x4/CheapTri...l#WindowSwitch
Ok so I did a little testing over my lunch break. It appears that the rocker is not the only problem. I pulled the switch out and pulled it apart. From what i can see it gets power out of the switch down to the window motor how ever the window only rolls down still no up movement.
Adam
Adam
So I kinda figured it out at least what the problem was. I was having a grounding issue in the driverside door panel. I got that figured out and I can now roll both windows up and down with the driverside now I just have to rework the passenger side again so I can roll that side up.
Adam
Adam
06-01-2021 01:51 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
01-16-2016 06:38 PM
icentropy
07-14-2015 10:23 AM
Johntom240
7
07-13-2015 12:18 AM
