85 4runner wont run, turns over fine
Hi,
I have a 1985 4runner that strangley stopped running. 22re w/automatic 186k. i drove to work and back one day and two days later it would not start, it turns over and that is it.
so far, tested voltage at fuel pump and its only getting .3 volts (weird). ran a jumper wire to it off the battery. pump worked just fine.
motor is not getting spark. tested two diff cylinders, and not getting power to or out of coil. ran hot wire to coil pack and fuel pump. engine started but ran very rough.
engine would not rev past 2-3k before sputtering out as if its flooding. check engine light finally came on but assuming its from us bypassing the computer controls but i dont know for sure as i dont how pull a code out of her.
all the fuses appear to be good, engine ran well until this point...thank you for any help/suggestions.
me and my buddy had the same problem monday with his 95 4runner with a 3.0 it would turn over fine but wouldent fire after i checked the fuses i notesed the EFI fuse was blown after replacing it it started right up
OK i have the SAME poblem im driving down the road when bam! truck dies and since then it turns but doesn't start. 94runner i've now replaced the coil, ignitor, the efi relay, and there is still no spark from the coil. whats going on??? SOOO FRUSTRATING as this is my DD. thanks for your help guys get back to me please!!!
Check the Ignition and EFI fuses, my 86 4Runner did the same thing one day, the fuses were good but they had a thin layer or corrosion on them and lost power. I replaced the fuses and all was good and it started right up.
hey guys I FIXED IT!!!! CHECK IT HERE!!! https://www.yotatech.com/forums/f116...t-come-190314/
indeed i had screwed around with it about 2 weeks ago and accidently knocked those wires around. and sure enough that was it. on that link up there what his problem was WAS LITERALLY what happened with me =D
Team420
01-12-2021 04:57 PM
91toybeater
12-27-2015 07:46 PM
yourrealdad
7
07-21-2015 08:53 AM
sharrack
06-26-2015 09:33 AM
