85 4runner wont run, turns over fine
Old May 20, 2010 | 10:40 PM
cnelson580's Avatar
Hi,
I have a 1985 4runner that strangley stopped running. 22re w/automatic 186k. i drove to work and back one day and two days later it would not start, it turns over and that is it.
so far, tested voltage at fuel pump and its only getting .3 volts (weird). ran a jumper wire to it off the battery. pump worked just fine.
motor is not getting spark. tested two diff cylinders, and not getting power to or out of coil. ran hot wire to coil pack and fuel pump. engine started but ran very rough.
engine would not rev past 2-3k before sputtering out as if its flooding. check engine light finally came on but assuming its from us bypassing the computer controls but i dont know for sure as i dont how pull a code out of her.
all the fuses appear to be good, engine ran well until this point...thank you for any help/suggestions.
Old May 20, 2010 | 10:49 PM
1981 yota's Avatar
me and my buddy had the same problem monday with his 95 4runner with a 3.0 it would turn over fine but wouldent fire after i checked the fuses i notesed the EFI fuse was blown after replacing it it started right up
Old May 21, 2010 | 07:46 PM
cnelson580's Avatar
Thanks bro,
I will take a look at that fuse. Im thinking it could also be the Circuit Opening Relay.
Old May 21, 2010 | 08:17 PM
1981 yota's Avatar
welcome man
i bet its something so easy you dont even think about checking it lol
Old Jan 26, 2011 | 02:10 PM
Blue Steel's Avatar
OK i have the SAME poblem im driving down the road when bam! truck dies and since then it turns but doesn't start. 94runner i've now replaced the coil, ignitor, the efi relay, and there is still no spark from the coil. whats going on??? SOOO FRUSTRATING as this is my DD. thanks for your help guys get back to me please!!!
Old Jan 28, 2011 | 01:53 PM
myyota's Avatar
Check the Ignition and EFI fuses, my 86 4Runner did the same thing one day, the fuses were good but they had a thin layer or corrosion on them and lost power. I replaced the fuses and all was good and it started right up.
Old Jan 28, 2011 | 05:10 PM
Blue Steel's Avatar
ok ok myyota. i've checked all the fuses too. was this corrosion visible? i already switched out the efi fuse that sucker was $30 bucks. thank you
Old Jan 28, 2011 | 05:11 PM
Blue Steel's Avatar
that ignition fuse is under the hood right? or under my steering wheel?
Old Jan 28, 2011 | 08:57 PM
myyota's Avatar
The efi and ignition fuse are behind the driver side kick panel inside the truck. I have no idea what fuse you replaced that was 30.00 dollars.
Old Jan 29, 2011 | 08:11 AM
1981 yota's Avatar
in the newer 4runners the EFI fuse was under the hood on the left side. at least on my buddys 95
Old Jan 29, 2011 | 04:03 PM
Blue Steel's Avatar
hey guys I FIXED IT!!!! CHECK IT HERE!!! https://www.yotatech.com/forums/f116...t-come-190314/
Old Jan 29, 2011 | 04:17 PM
myyota's Avatar
So you had a bad AFM ?.
Old Jan 29, 2011 | 04:38 PM
Blue Steel's Avatar
indeed i had screwed around with it about 2 weeks ago and accidently knocked those wires around. and sure enough that was it. on that link up there what his problem was WAS LITERALLY what happened with me =D
Team420
Jan 12, 2021 04:57 PM
gillesdetrail
Nov 19, 2019 12:56 PM
91toybeater
Dec 27, 2015 07:46 PM
yourrealdad
7
Jul 21, 2015 08:53 AM
sharrack
Jun 26, 2015 09:33 AM
