4RunnerKid's 1993 4Runner Build-Up Thread
Old Aug 22, 2007 | 05:01 PM
  #161
4RunnerKid's Avatar
the tabs in the first pic are for the upper knuckle ball gussets/shock mounts. i have similar tabs (minus shock mounts) for the bottom as well, i just didn't take any pics of those.
the housing isn't too heavy, but it definitely weighs more than a stock one. if i bend this housing i'm not sure what i will do... probably D60s, but hopefully it doesn't come to that.
Old Aug 23, 2007 | 10:56 PM
  #162
4RunnerKid's Avatar
a little more progress...
Old Aug 25, 2007 | 11:32 PM
  #163
4RunnerKid's Avatar
all that's left are the knuckle balls...
Old Aug 26, 2007 | 05:48 AM
  #164
waskillywabbit's Avatar
Looks good...I hope you took your time and went SLOW with all that welding.
Old Aug 26, 2007 | 06:37 AM
  #165
Marc P's Avatar
X2...looks very beefy
Old Aug 26, 2007 | 09:28 AM
  #166
4RunnerKid's Avatar
i took my time, definitely. the front truss was done inch by inch... the upper was tacked in a bunch of places and i welded every 4th inch section or so, let it cool, did the next set, etc.
Old Sep 9, 2007 | 09:15 PM
  #167
4RunnerKid's Avatar
Old Sep 9, 2007 | 09:21 PM
  #168
KevinInSac's Avatar
Beefcake
I don't think that front axle is going anywhere.
Old Sep 9, 2007 | 09:27 PM
  #169
stormin94's Avatar
Originally Posted by 4RunnerKid
[img]https://www.supermotors.net/getfile/561914/fullsize/picture-066.jpg]
I like what I see, esp. what's on the hood. I'm guessing that helped you out through some of the frustrations of this build.
Old Sep 11, 2007 | 08:48 PM
  #170
-TheBandit-'s Avatar
The axle looks great. Looks like your tierod is awfully close to the springs though!
Old Sep 12, 2007 | 04:09 PM
  #171
4RunnerKid's Avatar
thanks for the kind words guys. i had the truck aligned the other day and everything checks out pretty damn good. slowly but sure i'm getting this thing "done." some poser pics form today:
Old Sep 13, 2007 | 11:34 AM
  #172
idayota's Avatar
you know, it does look close, but i had about the same clearance on my '84 with hi-steer and it never rubbed. as far as i could tell, there is no case where the spring is actually going to get much closer to the tie rod...it just doesnt flex that much near the u-bolts...always worked for me.
build looks great! could you shoot a couple pictures of the tabs you welded on the lower part of the ball joint? at first i was sure you had created a weak spot at the ball joint, but those tabs will sure help. are they boxed or flat iron? think you'll bend em up on rocks?
Old Sep 13, 2007 | 11:36 AM
  #173
idayota's Avatar
did you have that top truss made or did you buy it somewhere? it looks good.
Old Sep 13, 2007 | 08:51 PM
  #174
4RunnerKid's Avatar
i have 3/4-1" of clearance between the tie rod and springs, and i've never had a problem with them touching. every piece on the axle was designed and cut out by myself or my roommate. i didn't buy anything except for the steel. as for the lower knuckle ball gussets, there are two pieces of 1/4" plate an inch apart, and they are boxed in with 1/8" plate between them. (1/4" -> |_| <- 1/4", 1/8" for the bottom line) rocks aren't going to bend them...
Old Sep 14, 2007 | 08:50 AM
  #175
idayota's Avatar
makes sense...looks good too. well done!
Old Oct 20, 2007 | 11:52 PM
  #176
4RunnerKid's Avatar
out with the old....
also picked up a few goodies recently... something along the lines of 217:1
Old Oct 21, 2007 | 01:25 PM
  #177
Blizzard's Avatar
Mike, stop modding your truck because I've not started my SAS yet and I'm thinking in duals due to you!!! Hehehe
That setup will be nice, are you replacing the auto with a manual trans?
David
Old Oct 21, 2007 | 01:41 PM
  #178
Prophet_MX's Avatar
Nice runner man! If I had a runner I would hook it up that way!
Old Oct 21, 2007 | 05:31 PM
  #179
4RunnerKid's Avatar
yeah, the auto is getting replaced with a manual. so far i've picked up two top shift gear-driven cases, the marlin V6 to gear-driven adapter, and a TG 23-spline 4.7 gearset. my goal is to have the duals done by new years for a trip. new trans should be in next weekend.
oh, sorry david... it's just a sickness i guess. looking forward to see your build, for sure.
Old Oct 21, 2007 | 06:25 PM
  #180
Tylerars24's Avatar
nice truck
so whos the babe?
