What tranny for a 85?
Old 12-07-2007, 07:42 AM
Dimer13's Avatar
I'm doing a 5-speed swao and I'm not sure what tranny/t-case I need to find. I found one out of an 88(w56?) What should I be looking for? I appreciate the help.
-Brett
Old 12-07-2007, 11:10 AM
tc
tc's Avatar
You have a 22RE right?
R151F out of a turbo would be the ideal tranny. Kinda hard to find though
Old 12-07-2007, 11:14 AM
fillsrunner4's Avatar
Easier would be the w-searies because it will bolt right up same with the r151f but like stated they are hard to find and not cheap. you could also go with the r150f and get the marlin adapter but in the end the cost would be pretty high up there just like the r151f. Ide probably say w-series. What do you do with this rig? wheel, DD, both?
Old 12-07-2007, 11:16 AM
tc
tc's Avatar
I thought Marlin's adapter was for the 2RZ and 3RZ - do they have the same pattern as the 22RE?
Old 12-07-2007, 11:28 AM
Crap ya i think your right about that for some reason i was thinking it was for the earlier 22's aswell. However arent the new motors basicly like the old as for as bolt patters go? Just like how the 3.0 and 3.4 are the same the newer modle 4clys i think have the same patern also making it posible to mate the r-series to the old not just the new
Old 12-07-2007, 05:45 PM
tc
tc's Avatar
Well, the 3.0 (3VZ-E) and the 3.4 (5VZ-FE) are the same block - that's why everything is interchangeable.
The 2.4 (22R-E) is a totally different block than the 2.7's (2RZ-FE and 3RZ-FE). Bolt pattern could be the same, but it's not as likely as it is with the two v6's
ladybugRC
458
08-21-2020 10:41 AM
TheBFA
02-15-2020 06:55 AM
live4soccer7
05-11-2016 06:52 PM
Davebarbier
11-03-2015 03:28 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: What tranny for a 85?
