Powertax No-slip
Powertax No-slip
Anyone know anything about the Powertrax No-slip? I'm wanting more traction and I don't have the money for the ARB right now , but I don't want a noisy lunchbox locker. I've heard some good things about the Powertrax No-Slip, but can't seem to find an application for a 3rd gen rear-end. Does anyone run this in their 3rd gen or know what model number it is for my rig?
The Powertrax is a lunch box type unit. I have it in my Downey catalog, right here.
It is nearly identical in design to my aussie, except that it's windows for the shear pins are much much larger (Aussie claims this degrades the powertrax's strength)
They have a unit that will fit a 95-01 tacoma, t-100, or tacoma 8" (It does not say 4runner, but isn't it the same axle?)
The cost through downey is 449.00
Give downey a call and they can help you decide if that unit will fit or not, but be aware that it is a lunchbox locker.
If you're going to go this route, I recommend the Aussie locker (www.offroadlockers.com) it has behaved well for me.
If you don't want a lunch box locker....check out the detroit soft locker. It is supposedly soft like the no slip or aussie, but requires you to replace the full carrier like a detroit or ARB.
jonathan,
researched this route to death about a month ago! basically if you dont want the clunk of the lunch box-type lockers, youre either going to have to wait for aussie locker to come out w/ their 3rd gen 4runner lockers (which is a lunch box type) or rob a bank and get the ARB selectable locker w/ air compressor.
the other option (while not technically a locker) is to buy a detroit true-trac. its an LSD but a few guys that have it here and on 4x4wire say its awesome on the road and gives better traction off-road as well. the most common statement i kept reading was "its great on the road and helps off-road...and its definitely better than having an open diff"
thus, i'll probably get a detroit true trac since I use my 4runner mostly on-road and occassionally off-road.
bob
bob
Originally Posted by Bob_98SR5
jonathan,
bob
bob
Originally Posted by <96 Runner>
Or you could always snag an entire e-locked axle from a junk yard and do the swap. It's not that hard, really.
www.inchwormgear.com has all the wiring you need for install for like $70
you will need to modify the axle housing consisting of filling some holes, grinding and welding in a couple of new studs but its looks pretty easy and there is a writeup on www.4x4wire.com i beleive
Originally Posted by jimabena74
[you will need to modify the axle housing consisting of filling some holes, grinding and welding in a couple of new studs but its looks pretty easy and there is a writeup on www.4x4wire.com i beleive
I got my ECU from ABQ_Jim here on Yotatech for $50. I am sure you could snag the ecu from the donor rig. It's just a little module under the left side of the dash that also does something with the ABS.
Let me know if you have any other questions.
Personally I would do the e-locker if you have the choice.
Email aussie, they got back to me quickly about every one of my questions.
As far as the aussie behavior. It isn't bad. BUT, it is a locker. When you hit the gas, it locks, plain and simple. IF you gas a turn it will chirp or squeal depending on how long you hold the pedal. Parking lot manuevers are a little quirky at times, but I expected them so it isn't bad.
It will take you a second to relearn your vehichle. Simply dump the clutch on tight turns or corners. This causes the ratcheting sound rather than the chirp. (The ratcheting sound is inaudible unless I have the stereo and fan off ....it's that quiet)
You'll be surprised what a locker can help you through, this thing amazes me constantly. For the type of wheeling I do, I think a rear locker will be enough.
Awesome thanks guys!
Christian- might be in touch with you soon, I'm capable of switching the axles, but i'll probably need some help on the wiring, this is of course if I can find an entire axle.
Deathrunner- I still might go with the aussie if this doesn't pan out. It would be a definite if I wasn't in the city all day long, but I definetly want to get something soon.
I'll keep ya'll posted and if anyone has any more suggestions, let me hear em
yeah, these complete rear axles w/ elockers are a B to find.
i cant wait for that aussie locker to come out. i read a review on pirate's forum and the guy who did it said it was really quiet as compared to other lunchbox lockers.
(you hearin' this, aussie lockers?!? you got a market ready and waiting!)
bob
Hello,
I know that ARB or E-Lockers are best, but if like me you can't or don't want to afford that, I recommend you to put an Aussie or a Detroit Soft Locker.
I run Aussie in front and Detroit Soft Locker in the rear. I wanted to put both Aussies but my 4Runner had factory LSD so I haven't an open carrier.
Bill Cole from Aussie is a great man and answered patiently my ton of emails asking for all the details.
The Aussie and the Soft Locker are quiet. I only notice the Soft Locker in tight turns if accelerating.
I'm anxious to test them in the trail.
David
David
David
David
Remember, being locked front and rear changes the way your vehicle handles, especially on side hill or off-camber situations. If the soil is soft or loose, like in snow, mud, sand or gravel, you will tend to slide down hill. This is true w/ a rear locker too, but the front locker makes it worse.
There is no Aussie locker for the V-6 8" Toy diff.
The Powertrax is a locker.
Any lunchbox locker is going to click and bang, that is the name of the game.
I could not imagine wheeling open diffs. It will blow your mind.
Hey all,
I just finished reading everybodys replys and have learned a lot. I have a 95 4runner v6,auto. I use it alot on the highway but out on trails more now
I just got through talkin about the Powertrax with one of the guys at Central 4wd (Cali) He siad its a pretty reliable piece. I was just wondering if its a smoother reaction with a auto trans? I guess though lunchbox is lunchbox.
if I do this Im throwin in the 4.88s as well. I still am amused(as well as others that I took open difs out on CA4WD's winter fun fest lol ! Only needed yanking once and a push to back out of a scary trail.(deep snow and steep drop off not fun when you start sliding...)
justdifferentials
Just Differentials
08-15-2015 05:25 PM
rngrchad
14
01-31-2009 07:33 AM
ovrrdrive
03-04-2007 07:00 AM
