a little bit of shock trig
#102
Well, two conditions to look at with inboarding the shocks, with them mounted vertically. For straight up and down suspension movement (equal on both sides), it makes no difference where the shock is mounted as the whole chassis moves up and down equally relative to the axle.
Only for cases where you have body roll or axle articulation will there be a difference. And then, you'll see two factors at work, both related to the inboarded shocks. Firstly, their leverage on the axle, relative to the wheels will be reduced by their degree of inboarding. But then, just like the angled shock case, the shock will compress slower the more inboard it is mounted, and thus will generate less force.
So you again get into a case where you have less force acting with less leverage so those two effects must be combined, at least for the body roll case. So for a shock mounted 1/2 way between the WMS and center, it has 50% leverage against rolling and will make 50% the force since it compresses only 50% as fast as if it were out farther, so it is 25% as effective as the same shock out at the WMS (which of course is not practical to do).
The "real" effectiveness would lie someplace between the up-down value and the roll value, depending on what mix of suspension travel you wished to test the system with.
#103
Oops, missed that. Good catch.
EDIT:
And just for good measure, a graph comparing the qualitative behaviors of angled and inboard shocks. I made the X-axis a ratio, where for the angled shocks the angle is 90deg*Ratio, and for the inboard shocks a distance ratio measured from the WMS divided by the distance from WMS to the center of the axle. Obviously, there is no cross-over optimization in this case...
EDIT AGAIN:
Or if you prefer, a pretty picture comparing the two. "Overall Effectiveness" is defined as (Angled Effectiveness) * (Inboard Effectiveness). Also added a contour plot which is possibly useful for seeing where your shocks sit in terms of overall effectiveness.
#104
just wanted to say that i do see your view, and it made me think a bit.
i learned a lesson, and am actually seeing how you could be right. foot in the mouth huh, lol.
oh well. on we move.
thanks roger. in the entire system i do believe you are correct assuming velocity doesnt change due to the less force output by the angled shock, thus making it a non-cyclic problem. my professor and i were thinking of the problem as the book posted does.
im difficult to convince sometimes, but thanks for keeping it up.
#105
Well, it is cool that we all learned something.
however, i could care less about that, as we have now 5 pages of thread, and no updates
I would like to see your progress on the vertical 4 shock set up. This sounds pretty cool, and like it can work. I am interested to see your plans, and if you've gotten work done thus far. Pictures are a must.
#106
actually ill be doing the two fox inboard shocks, and a sway bar in the rear i believe.
will be analyzing it in matlab for my land vehicle dynamics project this semester. will possibly make a thread about it when i get it done over summer.
#107
Speaking of over-shocking...
Saw this Toyota Pickup at Truckin' Nationals in Phoenix and wanted to slap the owner:
#109
yes this thread is old
keep coming up with formulas and a few pics and some say so's here and there. so does mounting them inward at a 45* allow more flex yay or nay? my rear does not seem to flex much.. chevy's are in the process it might as well be as stiff as a dead body
#111
- http://www.4crawler.com/4x4/4R_suspe...tml#ShockAngle
I know with the factory rear shock mounts on the frame and lower spring plate, you are really limited by having a shock with a short enough compressed length to allow the springs to compress the bump stops and that then limits how far that same shock can extend.
#113
127 shocks and still using push pull steering??
all of this banter and do we have an ULTIMATE result of ideal placement of shocks? or should i just mount the sky mfg rear shock hoop where ever i want to?
#115
Holy old thread revival!
I started this thread feeling entertained. I even felt like I understood what was going on at first. Then... I began to see numbers and symbols and odd equations, and I began to feel very very stupid. The interesting thing is, I actually read through the thread and with what high school math I still retain, I sort of understand it. I now feel smarter, mostly due to some VERY well thought out and explained arguments. I also have a certain amount of respect for the OP, who was man enough to admit his mistakes.
In short, it moved me.
#116
And over the years, I have used almost all those points as I fine tuned the setup.
#117
wow...the OP is an A-hole, lol... ahh so much learned since then. mostly complete research before speaking.
I did go ahead and do the two vertical fox shocks spaced at about 75% of track. they are vertically mounted. ride is pretty rough and I am now considering leaning them in about 15-20* for a bit less damping.
Blamalam
03-12-2022 07:34 AM
he's gone
7
12-03-2019 07:08 AM
punks_is_4x4
08-21-2015 01:35 PM
terminator
07-27-2015 07:13 PM
