Correct Caster for Dana 44 SAS
Ok guy's, gal's,
How many degrees of positive caster did you use when rotating the inner knuckles on your Dana 44 SAS?
This is assuming the weight of the vehicle is on the axle at the time of setting the degree's of caster.
Thanks
Don
Thanks
Don
You might have better luck over on www.ttora.com or even Pirate.
Stock on the Toyota axle is ~2 degrees:
http://www.4crawler.com/4x4/4R_TechInfo.shtml#Steering
Usually can go a little more than that with larger tires.
JookUpVandetti
09-24-2015 02:58 PM
justdifferentials
09-05-2015 06:52 PM
