Can 4" clear 35"s
Usually the 4" IFS lifts will require that you run 3.5" or so backspacing on the wheels to clear the lift. This will push the wheels and tires out from the body and increase the likelyhood of rubbing, so usually you need 2" body lift + 4" IFS lift to clear 35s:
Lift vs. tire size info.
I was hoping to get a 4 in. trail master kit because it uses blocks in the rear so i could keep the add-a-leafs, and adjusted torsion bars i already have plus the trail master kit for about 5.5 or 6 in. total lift i just wanted to know for sure i could clear 35"s with that before i got it. Thanks for all the info.
live4soccer7
05-11-2016 06:52 PM
JookUpVandetti
09-30-2015 08:58 AM
charlie_fong
09-27-2015 10:06 PM
