Wheres a good grounding spot for lights?
Old Nov 21, 2004 | 02:08 PM
Gangus2006's Avatar
I think Im gonna do some more witing for my Hella 500s tomorrow, and was wondering where is a good place to ground them. Is the grille gaurd sufficient? Is there a place close by behing the grille to ground?
Old Nov 21, 2004 | 02:18 PM
User 051420's Avatar
In front of the radiator, there's a couple bolts that work well. The grille guard should work also.
Old Nov 21, 2004 | 02:20 PM
waskillywabbit's Avatar
Talking
Just run a wire to the ground that the ground off the battery uses on the inside of the fender well as you know that one is good.
Old Nov 21, 2004 | 02:39 PM
Brendan's Avatar
anywhere with bare rustless metal should be fine.
Old Nov 21, 2004 | 03:00 PM
Fink's Avatar
Any of the random holes that are drilled into your engine bay will work, I just used the two right in front of the radiator as mine...haven't had any problems yet. If you can't find any close enough to where you mounted your lights...just make your own spot
Fink
Old Nov 21, 2004 | 05:26 PM
Gangus2006's Avatar
So this ground dosent have to be PERFECT like a high power Amplifier? As long as its connected to a piece of metal its good? w00t..easier than I expected...
Old Nov 22, 2004 | 08:55 AM
Flamedx4's Avatar
Drive a 36" steel stake into the ground, install a ground clamp on it, and run a solid 10 ga copper wire to it and clamp it on...
Old Nov 22, 2004 | 03:05 PM
ewarnerusa's Avatar
haha! that should be sufficient. Make sure to run enough copper wire to cover the distance from home to work.
My lights are grounded just through their mounts to the bumper. I also ran the ground wire to the bumper.
Old Nov 22, 2004 | 03:11 PM
Darx's Avatar
My Hella's directions said to hook it up to the negative terminal for the battery. If you don't want to do that there's always the ground on the fender for the battery as someone already mentioned.
ashersullivan88yota
Jan 18, 2022 05:37 PM
Sep 4, 2015 09:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
madxman21
Jul 9, 2015 10:26 AM
colinmil
Jul 6, 2015 04:03 PM
