where to get brass bar?
Old 04-17-2004, 01:45 PM
Rays94runner's Avatar
I just got my Aisin Manual Hubs Where can I get one of those brass bars to get the famous cone wahers off. I looked at Home depot and autozone. Would they be in the tool section? Hmm I bet my girl has something brass around here I could use. better not!! I think I'll repack the bearings and do the front brakes while Im at it
Old 04-17-2004, 01:54 PM
kyle_22r's Avatar
maybe go to the section at home depot where they sell steel rods, i'm pretty sure they sell brass ones as well...then just cut it into usable lengths
Old 04-17-2004, 08:53 PM
SoCal4Running's Avatar
Any local metal supply stores should have what you need. Sometimes there a gold mine.
Old 04-17-2004, 08:57 PM
AgRunner06's Avatar
No brass bar required.
You don't need a brass bar to get the cone washers off.
Here's what you do:
1. Soak the nuts and cone washers with PB Blaster.
2. Unscrew the nuts but don't remove them.
3. Tap/hit the side of the of the ADD hub (where the cone washer is) with a hammer until the cone washer pops out.
4. Remove the nut and washer.
5. Repeat until all washers have been removed.
Very simple to do and no brass bar is required.
Make sure you rebuild you hubs before you install them. When I got mine, I could barely turn the dial.
Have Fun
Old 04-17-2004, 09:28 PM
Thanks, I probably wont start on them for a few weeks. I want to pick up a torque wrench 1st
Old 04-18-2004, 02:27 AM
sportJr's Avatar
I just used a small flat head screw driver, ones size bigger than an eyeglass driver. Put it on the grinder to give it a point and tapped it right in to the gap. Popped off like a charm.
Old 04-18-2004, 04:14 AM
Cebby's Avatar
I'm either going to buy or make one of these...
Old 04-18-2004, 07:40 AM
Arnold's Avatar
Got mine from Harbor Freight Tools.
ladybugRC
458
08-21-2020 10:41 AM
Dale Johnston
11
10-31-2015 10:22 PM
A2theK
10-14-2015 07:10 AM
Obmi
10-04-2015 11:30 AM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: where to get brass bar?
