Weak heating
Old 01-25-2004, 09:31 PM
ASU4runnin's Avatar
Weak heating
Anyone noticed weak heating in their 3rd gen?
I recently had 120k Lexus service with new belts, water pump, O2 sensor, etc and was told this would help, yet Im still freezing in the Appalachian Mtns!
Ideas?
Old 01-25-2004, 10:52 PM
Blair's Avatar
Coolant Level
Mine is great for toasting marshmallows, if I set it on 'high'.
Check your coolant level. Sometimes, if it gets too low, it can't reach the heater core. Which leaves you very chilly. Could also be a blocked heater core.
Del, how did you make out with your heat issue?
Old 01-26-2004, 03:02 AM
MTL_4runner's Avatar
Re: Weak heating
Ideas?
I am having some trouble with my 3rd gen too (varies greatly with outside temps).
May be that the heater core needs a good cleaning (my guess).
I checked all the duct gates and they are sealing correctly.
It is not a water pump issue I am quite sure.
If I find more I will post.
Anyone else have this problem?
Solution?
PS also clean your blower motor while you are in there.
Old 02-02-2005, 06:18 PM
Since heating threads are more relevant now I will send this thread BTT too.
Doesn't seem anyone has solved this issue yet.
TheBFA
02-15-2020 06:55 AM
Davebarbier
11-03-2015 03:28 PM
mreagen
10-05-2015 04:27 PM
Obmi
10-04-2015 11:30 AM
Matthew Perez
09-28-2015 05:43 PM
Quick Reply: Weak heating
