Ticking sound.
Ticking sound.
There is a slight ticking sound coming from my engine bay. It seems to come from the driver side of the motor. I had it checked out at the dealership and they said it is normal. Does this seem normal? BTW. It is a 2001 4runner limited with 56k miles. I also have a 1997 limited (with 158k miles) and it does not make the ticking noise. Any input would be appreciated.
Thanks
Paul
Thanks
Paul
I am not sure if it is the same thing, but I have a ticking sound that comes from a module/sensor on top of the Charcoal Canister on the driver’s side of the engine bay.
Not sure if this is normal or not....
Originally Posted by PoBoy
Do you hear it from the inside of the truck? Does it go away when you press on the gas?
Originally Posted by PC97M3
I do not hear it from inside the truck. It does not go away when I press the gas. But, when I first startup in the mornings, I do not hear the ticking.
Thanks
Paul
Thanks
Paul
I'm new to Toyota, but didn't they switch from timing belts to timing chains somewhere along the line? Anyway, whatever the sound is, if your Toyota dealership says it's normal, relax and forget about it. They are doing you a favor.
Stockerjo
I have the same ticking on the passenger side of my 98 3.4. I can hear is slightly at freeway speeds too. It is the EVAP valve by the charcoal canister and heard this was normal. I know there was a fix for some late models. You can distincly hear the noise coming from there if you lift the hood and listen closely to it.
Originally Posted by InFlames
look for missing bolts or nuts on the exhaust headers flanges they fall out sometimes and cause a small crack that lets exhaust escape and make a ticking noise when you applythe gas..
larrys93pickup
09-06-2015 06:37 AM
