Swap 99 cluster for 01?
I've been searching all morning and can't find anything. Is a 01-02 4runner cluster wire compatible with a 99-00 4runner? I've got gas gauge issues and don't want to play cluster roulette with 99-00 clusters and end up with the same problem. I can't find any place that will sell the combo plate #3 without having to install it as well, and I can find used clusters for less than the price of the new plate.
The fuel gauge electronics is part of combo plate #3, which handles the odo, speedo, etc. I don't see how I could switch just that if they aren't wire compatible.
Just went out and verified on a cluster that the Fuel gauge is indeed seperate from the speedo, etc.
In fact, Toyota does list two different part numbers for the two years.
99-00 83882-3D250
01-02 83882-3D570
You MIGHT be able to swap these fuel gauges. I was slightly incorrect when saying you COULD, or at least a little vague. Just because it will swap, doesn't mean it will work correctly. Again, different electronic systems.
99-00 83882-3D250
01-02 83882-3D570
Circuit board?
In that case, the circuit boards definetly cannot be swapped. The biggest glaring difference is AWD which the 01-02 has, while the 99-00 is true 4WD. The 01-02 gauge cluster has a big chassis/awd indicator smack dab in the middle, the 99-00 just has a 4WD light. The clusters are wired totally different
My 99 Limited has the big chassis/awd indicator smack dab in the middle. I have the AWD mode as well.
The combo #3 is the same for all 99-00 4runners, regardless of 2x4 vs 4x4, or auto vs manual, or limited vs sr5. There is a difference between vin numbers though. VZN18 has a different part number than RZN18.
Regardless, I found a blown resistor on the back of my current board, and jumpered around it. Now my fuel gauge is working perfectly again. Thanks for the help!
Esibnitsud
07-30-2015 08:21 PM
