Starter Problems
Old Sep 8, 2006 | 10:55 PM
TMR's Avatar
TMR
Exclamation Starter Problems
I am assuming that my problem is the related to the infamous starter contacts, however I would like to make sure. Obviously I am experiencing problems starting, however my problem is somewhat different.
Instead of on going problems, my problem is completely out of the blue, and instead turning the key over to a single click, I turned the key over to a rapid and repeditive click, click, click, click, click....until I release the key.
I would like to assume this is the starter contacts which so infamously plague our trucks...If anyone has any knowledge about this I would greatly appreciate advice! I will be chasing down starter contacts tomorrow morning....
Many thanks in advance!
TMR
Old Sep 8, 2006 | 11:15 PM
Elton's Avatar
Welcome to YotaTech.... did it just start doing it ?
Old Sep 9, 2006 | 02:29 AM
8422r4Runner's Avatar
I would start by just cleaning up the battery connections. Sounds like not quite enough power is getting to the starter.
Old Sep 9, 2006 | 06:35 AM
Firefightertaco's Avatar
Yeah sounds like the battery. u might try cleanin the teminals or your battery might be dead. Try jumping it if cleaning the teminals didnt work.
Old Sep 9, 2006 | 06:53 AM
SlightlyModified's Avatar
could possibly be the hot wire goin to your startin, check it for corrosion, see if it's loose.
Old Sep 11, 2006 | 02:05 PM
TMR's Avatar
TMR
Thx
Thanks for all the help Guys, turn out it was just the battery after all!
Old Sep 12, 2006 | 11:19 AM
blackicewap's Avatar
I started having the same problem after cleaning out my engine. It happens off and on- I'm going to clean my battery connections to see if that helps at all. Thanks a lot.
Old Sep 13, 2006 | 08:00 AM
4Crawler's Avatar
Here is a simple test you can do to isolate the cause of the problem:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
Here is a picture of testing the voltage at the starter solenoid:
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
clok
Aug 1, 2015 09:42 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
