| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
SeaFoam options.
__________________
'02 4Runner - '06 XRunner Breakdancing www.BadgeYourRide.com Check this out Multi-Touch Interaction Research http://mrl.nyu.edu/~jhan/ftirtouch/ Highest Xmax 6.5" subwoofer made Total Posts: 32,218 (75.35 posts per day) [/center] [/color] Still A Neon Last edited by 4-RUNNIN' FREAK; 02-09-2005 at 05:27 PM. |
#2 (permalink) |
Any source that hooks up right after the throttle body. The Brake booster would be the easiest one to spot as long as it feeds all the cylinder you should be good.
__________________
02 4runner conversion complete! |
#3 (permalink) |
OK. Thank you much.
__________________
'02 4Runner - '06 XRunner Breakdancing www.BadgeYourRide.com Check this out Multi-Touch Interaction Research http://mrl.nyu.edu/~jhan/ftirtouch/ Highest Xmax 6.5" subwoofer made Total Posts: 32,218 (75.35 posts per day) [/center] [/color] Still A Neon |
#4 (permalink) |
Just did the third treatment, but it didn't stall after I put in ½ can so I stopped. The only time it stalled was when I would put my finger over the brake vacuum line as it sounded like it would stall.
This stuff + changing the air filter seems to have brought back tons of power on this Buick. It didn't smoke bad, just looked soome cars you would start on a cold day. 1 can in the gas ¾ in the oil 1¼ in the intake
__________________
#5 (permalink) | |
Quote:
__________________
'99 Taco PreRunner V6 3.4L
#6 (permalink) |
It was over the course of three applications.
__________________
#7 (permalink) |
The best way i would do it. Is let it injest it. When done suckin, turn off car and go back to it like in couple hrs are even overnight than start the car and gas it.
__________________
#8 (permalink) |
Gotcha!
__________________
#9 (permalink) |
I was reading a post on a (I think) Honda forum and it said to use it on the front and find a hose on the rear of the engine because it doesn't get to all the cylinders equally. I guess you can use left/right for transverse mounted engines. I have to look for it and see what you guys think bout it. Kinda makes sense, the liquid will fall into the front cylinders first and not really get to the back.
__________________
'02 4Runner - '06 XRunner Breakdancing www.BadgeYourRide.com Check this out Multi-Touch Interaction Research http://mrl.nyu.edu/~jhan/ftirtouch/ Highest Xmax 6.5" subwoofer made Total Posts: 32,218 (75.35 posts per day) [/center] [/color] Still A Neon Last edited by 4-RUNNIN' FREAK; 02-09-2005 at 05:58 PM. |
#10 (permalink) |
Seven treatments total so far. Not much smoke anymore. Less than one minute of very light smoke.
The last 4 treatments were, #4. Let it sit for 7 hours 5. Let sit for 1 hour 6. Poured Seafoam in and drove right away 7. Let sit 20 minutes.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Seafoam on a 3.0 | 1320ft | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 11-12-2005 08:41 PM |
| seafoam | woodworth | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 02-25-2005 03:56 PM |
| Just tried Seafoam | forum95 | 95.5-2004 Tacomas & 96-2002 4Runners | 41 | 02-05-2005 10:23 AM |
| Seafoam | 14thegipper | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 12-18-2004 06:03 AM |
