Replacing time belt on 3.4L.
Old 01-29-2009, 04:20 PM
Question Replacing time belt on 3.4L.
Hello all,
Does anyone know the torque spec for the camshaft pulley bolts? Also, which idler pulley is number 1? Is it the top pulley between the two camshaft pulleys or is it the one just below the water pump?
Thanks,
______________________
1997 4runner
Old 01-29-2009, 04:28 PM
skjos's Avatar
I believe the information you need can be found here:
http://www.4x4wire.com/toyota/maintenance/timing_belt/
Old 01-29-2009, 05:20 PM
Thanks, but it does not say which idle pulley is number 1 and which one is number 2. They also did not remove the camshaft pulleys so there is no torque spec.
I have been searching for this info and I can't find anything.
Thanks again,
_______________________
1997 4runner 4x4
Old 01-29-2009, 05:43 PM
Mason Dixon's Avatar
i have the factory service manual if you want it, send me a PM
Old 01-30-2009, 05:58 AM
mt_goat's Avatar
Online FSMs: http://www.ncttora.com/fsm/index.html
Old 01-30-2009, 06:07 AM
mrdoug's Avatar
The short answer is 81 ft/lbs... but get the FSM, it's like having a cheat sheet for working on your truck.
No 1. Idler pulley is down by the waterpump
Old 01-30-2009, 06:24 AM
mt_goat's Avatar
Originally Posted by mrdoug
The short answer is 217fl/lbs... but get the FSM, it's like having a cheat sheet for working on your truck.
Hi Doug! I know the crank bolt is 217ft-lb for the 5vz but is the camshaft bolt 217 too? At first I though he was asking about the crank bolt.
Old 01-30-2009, 06:27 AM
mrdoug's Avatar
Doh!.. crap. I missed that. I see torque specs on a timing belt change and automatically go to the most often asked spec for the pain in the ass bolt.
Editing my original answer... Thanks for catching that Dale.
If for nothing else, getting the FSM keeps you from getting bad info from people who mistake your question (like me).
Old 01-30-2009, 06:42 AM
mt_goat's Avatar
You're welcome Doug, I almost did the samething myself.
voiddweller
19
05-02-2016 09:10 PM
stagger_lee
03-29-2016 06:27 PM
layifioren
10
07-06-2015 02:26 PM
marcusSRG
06-27-2015 07:13 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: Replacing time belt on 3.4L.
