Question on Dash removal
Old 03-08-2004, 06:05 PM
funglenn
Guest
Posts: n/a
I have seen write ups on the removal of the instrument cluster, but how do you remove the piece of dash that goes across the whole car, the one that the passenger airbag seems to be part of?
Anyone have ideas?
Old 03-08-2004, 11:40 PM
Duffdog's Avatar
Anyone have ideas?
lots of screws and 10mm's hold that one on....it will take a while.
T
Old 03-08-2004, 11:45 PM
Bob_98SR5's Avatar
funglenn,
never done it myself, one of these days i might, but for now, seems more trouble than its worth. what are you going to do?
also, i'd do the smart thing and unplug the battery completely, disable the airbags and *then* go to town.
bob
Old 03-09-2004, 12:45 PM
funglenn
Guest
Posts: n/a
Originally Posted by Bob_98SR5
funglenn,
bob
I do not even know where to start with removing the dash, i was wondering could the squeak be coming from the dash flexing against the passenger airbag cover? My squeak seems to go away completely if I put a folded up towel between the door and the dash before I close it, thus putting pressure on the dash from the side.
Could I put WD-40 on the sides of the airbag cover?, or would this be bad for the airbag if it ever goes off?
Glenn
Old 03-09-2004, 01:00 PM
Bob_98SR5's Avatar
Glenn
Glenn,
I personally would not go through the trouble of removing the entire dash to do this. i think you're onto something though. if the source of the squeaking is coming from that area, have you tried removing the glove box and seeing if you can isolate and then fix it from there? i think that would be your first step.
bob
Old 03-09-2004, 01:02 PM
SLC Punk's Avatar
If you do decide to remove the airbag, be careful!
Most dealerships have special tools to plug into the connector so it won't accidently go off. Those things can go off with just a little static electricity on you!
Old 03-09-2004, 06:06 PM
funglenn
Guest
Posts: n/a
Glenn,
bob
I have become sooo skilled at removing the glovebox in under 2 minutes.. there is an electronic brain for the truck, a heating vent, and then the airbag system, there is not much there to rattle. I am thinking of the cover of the airbag itself... what do you think of oiling it?
Glenn
Old 11-21-2009, 02:49 PM
79la's Avatar
My 4Runner makes this rattling also at various moments. If I put a towel in between the door and the dash it goes away. Did you ever figure out what the problem was?
Old 11-21-2009, 02:58 PM
Staff
DeathCougar's Avatar
I don't believe his account exists anymore. You brought up a post from 5 years ago
There are a million things that COULD rattle in the dash, the fix is to simply track it down.
Old 11-21-2009, 07:30 PM
79la's Avatar
I believe my rattle is coming from top right corner where the dash meets the window...ideas? Because I have none...
Old 11-21-2009, 09:06 PM
Mtn Mike's Avatar
Mine's got plenty of funny squeaks too. If you can't track it down, a popular fix seems to be to invest in an upgraded sound system.
Old 11-30-2009, 05:29 PM
79la's Avatar
I figured it out. The dash is loose on the left side after the passenger airbag. Near were the dash meets the passenger door panel. I can hear it click when I push down on it. Must be a broken clip or something...
kazuya2416
04-05-2024 02:17 AM
ashersullivan88yota
01-18-2022 05:37 PM
coffey50
07-28-2015 10:55 AM
icentropy
07-14-2015 10:23 AM
jetspeedz
07-13-2015 09:32 PM
Quick Reply: Question on Dash removal
