Popping when Turning
Old 01-28-2004, 07:49 PM
cubuff4runner's Avatar
I did searches and it seems that a few people have had the same problem as me, but I didn't see any definate answers.
When I turn my wheel all the way to the left or the right I hear and feel a poping noise. It only does it once unlike the normal clicking when a CV joint is bad and the vehicle has to be moving. My sway bar bushings are new, one CV joint is new and the other has seemed to be in good shape with the original boot. Has anybody figured out what this noise is? Sugestions.
Jeff
Old 01-28-2004, 08:10 PM
Goose's Avatar
My '90 used to do that, when I was turning hard, if I remember right there is a stop in there, that tends to either get worn down or fall off.
Old 01-28-2004, 08:27 PM
I used to have a 2nd gen 4runner that the stops made noise. I believe the 3rd gens don't have the same setup and it isn't the same sound.
Old 01-29-2004, 03:23 AM
MTL_4runner's Avatar
Those are the CV joints popping due to the angle.
Make sure you are not in 4WD when you cut really hard.
Mine does it too but just in 4WD.
Old 01-29-2004, 05:34 AM
Runner4's Avatar
I had the same problem and it turned out to be the swaybar bushings. Although you said they are new, shoot some lithium grease on them to lube them up a bit and see if that takes care of the noise.
Old 01-29-2004, 05:51 AM
That is a new one.....I will check that too.
Old 01-29-2004, 07:46 AM
I think I found the problem. One of my sway bar links was loose. Hopefully this solves the problem.
Old 01-29-2004, 06:22 PM
DH6twinotter's Avatar
Hey,
Ditto what cubuff4runner and Goose said, It might be your steering bumpstops. My '90 4Runner used to make some loud popping sound when turned all the way to the left or right. You should have 2 bumpstops on either side. They are plastic caps that just get pressed on the end of a couple of screws (or whatever you want to call those). If these fall off or wear off, then your "screw" is just hitting part of the frame making a loud noise. I replaced all 4 of mine for less than $20 and no more noise.
Anyhow, hope that helps,
Have fun.
DH6twinotter
Old 01-29-2004, 06:26 PM
Sorry, I just realized you have a 3rd gen. Disregard my last post.
My bad.
Have fun.
DH6twinotter
Old 01-29-2004, 07:14 PM
The swaybar link wasn't the problem. Any other ideas?
Old 01-30-2004, 08:08 AM
Krash's Avatar
Where did you get them? The stealership?
Old 01-30-2004, 01:21 PM
Does it only pop in 4WD? 2WD? road conditions? speed?
Old 01-30-2004, 01:47 PM
It pops in 2WD and 4WD. Any road conditions and at slow speeds because I think cranking the wheel as far as it will go at any other speed would lead to .
Old 01-31-2004, 12:11 PM
Yes, I got them at the stealership.
Have fun.
DH6twinotter
Old 01-31-2004, 04:12 PM
Krash's Avatar
Cool, didn't mean to ask a stupid question was just interested to see if they could be bought anywhere else.
Old 01-31-2004, 05:36 PM
Wasn't a stupid question at all. My appologies if my blunt response made it sound like it was. I haven't looked any where other than the dealership, so I'm not really sure if they are available elsewhere.
Have fun.
DH6twinotter
Blamalam
03-12-2022 07:34 AM
SubiKing
08-21-2021 03:57 AM
okamikai
04-30-2018 10:19 PM
mskalmus
05-28-2017 07:51 AM
Hamonacracker
07-17-2015 08:33 AM
Quick Reply: Popping when Turning
