PCV location/Seafoam treatment on a Lexus? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-21-2005, 09:57 AM   #1 (permalink)
LSUMatt1514's Avatar
Send a message via AIM to LSUMatt1514
I want to do the same Seafoam treatment on my fiance's Lexus GS300 that I did on my 4Runner, but I don't know where the PCV is located or what it looks like. Are there certain vacuum lines that I could trace to find it? Would I use the same method on her car as our 4Runners? Later.
Matt
__________________
01' SR5 Sport Edition
Performance: Deck Plate w/ Amsoil Filter, ISR Mod, Dynomax Super Turbo w/ Pacesetter Tip
Exterior: Manik Brush Guard, Piaa 1000X, Piaa 540, OEM Skid Plate, Custom Sidemarkers, Clear Corners/Bumpers, H/L Alenzas, Thule Lappland Cargo Basket, Reverse Lamps, Silverstars
Interior: Stereo System, Dakota Digital Gauges, Coleman Inverter, Speedhut Gauges
http://community.webshots.com/user/phi1514
LSUMatt1514 is offline
Old 01-21-2005, 10:19 AM   #2 (permalink)
4Crawler's Avatar
On my 4Runner (22RE) I just used the vacuum purge line from the charcoal cannister. It was easy to get to, small enough to be able to modulate the uptake of the Seafoam and was at the inlet to the intake. I would think the PCV valve hose would suck on way too much liquid at once and the hose from it to the intake is too short to use anyway.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 02-26-2007, 06:40 PM   #3 (permalink)
Quote:
I am a newb, what line exactly did you use on your purge line? I would like to do the treatment to my 4Runner(22RE).
co4rnr is offline
Old 02-26-2007, 07:08 PM   #4 (permalink)
4Crawler's Avatar
Um, like the purge line is the purge line, denoted with a "P" on the throttle body and I added a "P" on the other end at the charcoal cannister:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/19.html
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 02-26-2007, 11:09 PM   #5 (permalink)
profuse007's Avatar
use the brake booster hose.
__________________
Tran,
oO 4runner - Millenium Silver
WTB: 01-02 4runner right(pass.) taillight .,~??▼.,~??▼.,~??▼
WTB: Hood wind deflector
profuse007 is offline
Old 02-27-2007, 05:52 AM   #6 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
You don't need to use the PCV hose only, any vacuum hose going directly to the intake will work fine (the closer to the throttle body, the better......just make sure it is after the throttle plate). Just pull off an intake vacuum line with the engine running and if you put a finger over it and feel vacuum, you can use it.
Remember to run some in the gastank first and then into the engine after (running 1 can per 1/4 tank of gas minimizes any possible fouling issues.....try to run at least 2 cans in 1/2 tank of gas through before putting it directly into the engine).
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 02-27-2007, 08:02 AM   #7 (permalink)
4Crawler's Avatar
Two reasons I chose not to use the PCV hose was #1 it is too short to fit into the can and #2 it would be too hard to control the flow of the Seafoam, since it such a large diameter tube. I even found the small 3mm ID purge line would suck in too much Seafoam at a time unless I regulated the flow.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 02-27-2007, 08:18 AM   #8 (permalink)
mkgarrison5's Avatar
you dont stick any vacuum hose in the seafoam! you tilt the can of seafoam and let the vacuum hose suck it out that way and have a rag for it bc it can get messy.. but dont stick the hose in the can
mkgarrison5 is offline
Old 02-27-2007, 08:39 AM   #9 (permalink)
gpcollen1's Avatar
I just stuck a funnel in the PCV hose and poured it in at a drizzle - pretty simple.
__________________
'99 SR5 Sport - Desert Dune: AirRaid MIT, OEM Air Filter, Toyo 265/75/16 ATs, Deckplate, PP Springs and Bilsteins, Cheapo nerf bars, Injector replacement impending
gpcollen1 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Seafoam into PCV throttle body or valve cover? Chapman88SR5 General Vehicle Related Topics (Non Year Related) 1 03-08-2007 07:23 PM
high mileage Seafoam treatment? co4rnr 86-95 Trucks & 4Runners 12 02-26-2007 06:55 PM
seafoam treatment question spudrunner 86-95 Trucks & 4Runners 8 12-05-2006 11:18 AM
CEL & VSC\TRAC Lights after Seafoam Treatment on 03' kaneman23 03+ 4Runner/GX470, & 05+ Tacomas 7 09-04-2006 08:38 PM
HELP adding seafoam to 2.7l pcv valve eric1bss 95.5-2004 Tacomas & 96-2002 4Runners 10 11-29-2005 07:45 PM
2009 InternetBrands, Inc.
