no 4hi, but 4lo works
Old 11-26-2005, 06:11 AM
northfacer581's Avatar
just like the title says. i noticed that 4hi wouldnt engage/light wouldnt come on last night. a jeep buddy calls me up and says hes stuck. go out there, start sliding a bit, so i shift into 4hi. light doesnt come on, neither do i hear that clicking noise from the transfer case. so i put it in 4lo, light comes on, i hear it from the transfer case, all tires start moving now, and out comes the jeep.
i really dont have any other information, i just find it odd that 4hi wouldnt work when 4lo works just fine. anything simple i could check? id like to have my 4hi working in case the snow that charlotte never gets does come. thanks.
Old 11-26-2005, 07:10 AM
Sequoia'd's Avatar
Don't know for sure on a '99 but my '91 has vacuum actuators on the front diff housing. Check to see if they are still connected or if a hose got pulled off.
Good Luck!
Old 12-03-2005, 10:11 PM
i just had my clutch replaced by 4wheelparts.
im thinking since they were dropping the t-case, they might have forgot to connect/do something? is there something i can crawl under the truck and check?
4wd hi/lo worked fine bout a week or so before i took it up there...im really thinking they just forgot to do something....i just find it odd that 4lo works fine.
Old 12-04-2005, 02:50 AM
anthraciterunner's Avatar
Same thing happened to me about a year ago. The light wouldn't go on and it wouldn't clunk. The toyota techs looked at it and insisted i needed to replace a really expensive part. I crawled underneath and unplugged the connector...blew it out and replugged it. It's been working fine so far. You might want to try spraying some electronics cleaner on the plugs and see if that does the trick.
Old 12-04-2005, 12:32 PM
any chance u could take a pic of what connectors ur talking about?
Old 12-05-2005, 12:38 PM
well 4wheel parts fixed it. no questions asked.
the switch/connectors for the 4wd were backwards or something like that. idiots.
Old 12-05-2005, 12:45 PM
Tacoclimber's Avatar
Glad to hear it got fixed. Nothing's worse than depending on your rig and getting let down. (Not that it happens a lot with our choice of trucks, but you know what I mean...)
Old 12-05-2005, 01:08 PM
i hear ya. yea i was really wanting to get this one fixed asap...cuz theres talk of some snow this week in nc, and i need the 4hi for that. it should be an interesting winter with this lock-right.
ashersullivan88yota
01-18-2022 05:37 PM
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
madxman21
07-09-2015 10:26 AM
Quick Reply: no 4hi, but 4lo works
