New Hood
Old 07-12-2007, 11:53 AM
BUZY's Avatar
New Hood
I'm looking to replace my hood with the one with a scoop. anyone know where i can find the best deal?
Old 07-12-2007, 03:35 PM
frodin1's Avatar
You can get one for around $250. That seems to be the average of what I found. If you go completely crap aftermarket, you can find it cheaper.
Old 07-12-2007, 03:57 PM
cvlighthouse's Avatar
Any that fit the 01 taco?
Old 07-12-2007, 03:58 PM
Staff
DeathCougar's Avatar
no the tacoma and 4runner have different mounts and body lines.
Old 07-12-2007, 04:14 PM
X-AWDriver's Avatar
You have to buy the hood,scoop insert parts (dealer only and wil;l run about $150) plus painting it can cost about $600.
Here's an older thread with some dealer part #s.
https://www.yotatech.com/forums/f2/hood-scoop-75259/
There's a lot of threads on the hood scoop so look around.
Old 07-12-2007, 04:30 PM
frodin1's Avatar
Actually there's a superceded part number just like everything else Toyota has done it to. 53301-35170 Hood and components! Trd parts4u $224.89
Old 07-12-2007, 04:43 PM
Staff
$224.89 is for a bare hood only. No guts.
Looks like the parts to assemble it would be $78.91 additional.
If you are also concerned about the hood insulator, that is $130.35 as well. They are different Scoop-non-scoop. So the total is now 434.15, plus paint and labor.
Old 07-12-2007, 05:03 PM
frodin1's Avatar
When I looked up the hood only it comes up with a 53301-35050. The other number says that it's the hood and components? What gives? Why do they have two different part numbers for the same thing?
Old 07-12-2007, 06:11 PM
Staff
its a subsection called hood and components. Generally Toyota doesn't sell things "complete", especially body parts.
Old 07-12-2007, 06:40 PM
frodin1's Avatar
Huh, Typical Toyota. It figures as much, they should have just left the part number as is then. Oh well, it's still not way out of control as far as cost goes. Good luck BUZY, order up!
Old 07-12-2007, 08:52 PM
BUZY's Avatar
thanks, will do
Old 07-17-2007, 09:46 PM
BUZY's Avatar
couple more question. can i use hood from different year model as long as they're 3rd gen? or am i stuck with using the hood specifically for 2000 model? also, can i use the insulator parts from my stock hood, the non-scoop, and just modify it a bit to fit the one with the scoop or is there just too much to modify?
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
Davebarbier
11-03-2015 03:28 PM
BimmerSage
09-17-2015 11:48 PM
Quick Reply: New Hood
