| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
ISR Mod
#2 (permalink) |
search Airaid MIT.
#3 (permalink) |
boy thats expensive
#4 (permalink) |
You could always remove the ISR cap the hole with a PVC end cap, drill a hole for the vacuum tube and you're good to go.
__________________
'99 Taco PreRunner V6 3.4L
#5 (permalink) | |
Sponsoring Member
Quote:
![]() If you're looking to leave the stock tube and just plug up the holes, then I found pieces to fit at both Lowe's and Home Depot. Again, pulling the intake and bringing it in makes things easier.
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#6 (permalink) | |
Quote:
__________________
2000 Taco SR5 V6 5speed TRD Airaid MIT Vortex muffler DEI 2-way Extang Tuff Tonno III |
#7 (permalink) |
yeah id like to replace the silencer all together and the reason why im a bit heistant to spend $89 for the airaid is cause im not sure if the sound increase is worth the extra omph. and lowes would have a PVC tube thats about 2.5" ID?
#8 (permalink) | |
Quote:
not sure i know exactly what you mean |
#9 (permalink) |
Its only loud if you have the deckplate mod or have opened up your airbox. If you have the deckplate, you can put it back in and the intake noise will be close to stock. My truck is loud only when i'm on the throttle. Otherwise it is tolerable.
__________________
#10 (permalink) | |
Quote:
#11 (permalink) |
You can get the same result if you make it yourself. The Airaid might be bigger in diameter in the middle since it is molded this way.With the tubing it will be the same diameter the whole length. The effects are probaly negligible. Also, since it is molded it has no seams or ribs to obstruct the air flow.
__________________
#12 (permalink) |
Took me about ten minutes to install.I don't have the deck plate mod, i just removed the elbow. Mines not loud at all.
#13 (permalink) |
I hope you people are not using PVC. PVC releases toxic gases when it is exposed tot he temperatures that exist under hte hood of your vehicle.
DO NOT USE PVC!!! |
#14 (permalink) |
I got mine for free! Went to a muffler shop, gave the guy the diameters for both ends. He said i'll try it and said "you can have it" I believe rerouting vacumn hoses for 99+ is easy. I didnt have to get anything else, just route the hoses.
__________________
01 4runner 4x4 SE (stupid Cntr lock diff,VSC,TRAC) **Stuff I've wasted my money on** *front/rear chicken fence *clear corners *Hella 500s *Lexus HID *PIAA LED bulbs *ISR, Breather,DP Mod *Amsoil filter *husky cargo liner *Cobra STX II *SE badge *Griot's stuff* Alpine CDA-9815+Infinity Reference+12"Fosgate Punch/amp *BFG A/T 32s *Bilstein HD *Perforated Leather Seats...Buncha other stupid things "Uh....I dont know what I'm doing" -Ray http://community.webshots.com/user/ray0227 |
#15 (permalink) | |
Quote:
__________________
2002 4Runner SR5 |
#16 (permalink) |
I'm seeing a couple takes on the ISR mod in this thread.
The original poster has a 99 runner... I dunno what steps are involved in that ISR mod but I do know that there are some versions where the intake runs through the silencer and another version where the silencer is plugged into the side of the intake. Talk about a plastic cap vs. a segment of pipe vs. Airaid are going to be confusing if this guy doesn't know which type of intake silencer he has. |
#17 (permalink) |
my 2001 came with the plastic cap on the intake plenum. so i just pull the hose from the intake silencer and rerouted it to that after i took off the plastic cap. Check the pics on write up and make sure you have the same set up. I'd think on on write up would be more accurate for your application.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Yet another ISR mod... | Tigerstripe40 | 86-95 Trucks & 4Runners | 0 | 11-25-2006 10:02 PM |
| ISR Mod | MysticGold04 | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 04-06-2005 09:34 PM |
| I am about to do the ISR mod | wvuviv30 | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 05-17-2004 10:25 PM |
| 1/2 ISR mod | wynn | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 06-29-2003 01:40 PM |
