YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-22-2004, 07:27 PM   #1 (permalink)
Churnd's Avatar
Send a message via AIM to Churnd
I have a small problem...
...but it's driving me crazy. Here's what happened.
Is that fixable?
Edit: In case you can't tell, that's the drivers side mirror.
__________________
-Chris
If you can't explain it simply, you don't understand it well enough.
Click here to search!
My Website
Churnd is offline
Sponsored Links
To remove this ad, register today!
Old 03-22-2004, 08:35 PM   #2 (permalink)
AgRunner06's Avatar
Send a message via AIM to AgRunner06
It looks to me like the screw that goes into the mirror broke off but I could be wrong. If that's the case, good luck getting the broken end out. You may need an Easy-Out to do it. Otherwise if nothing else is broken, it should be fixable. You should be able to unscrew the other piece of the screw and go to Home Depot or somewhere and match it up with another screw. If worse comes to worse, just watch ebay and you'll find a good deal on a used mirror.
Good Luck
__________________
"I'm your huckleberry." - Doc Holiday
- '93 4runner - Sold!
Current Ride - 2001 Chevrolet Silverado 1500 ext.cab, pewter, 5.3L, 3.42s, fully loaded, 68K miles.
FREE ROCKET!!!!
AgRunner06 is offline
Old 03-23-2004, 08:27 AM   #3 (permalink)
Staff
aviator's Avatar
looks like an owiee
The best advice I can give is replace the whole assembly they cost peanuts at the wreckers. To take off the mount all you have to do is carefully pry off the the blanking plate on the inside then loosen three screws and pull the thing off. I upgraded mine to the bigger 4runner power mirrors and it was easy ( except for fabbing up a new harness to run the mirrors/windows/locks . Hope this helps Aviator
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0
K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler
custom covered SR5 seats, map lights, factory AC
tv4184 style black interior conversion started
mods to come... header,
custom centre console, stereo upgrade
tinted windows
Founding member 1972TLC fan club
Toyota Hilux... Get in or Get out of the way.
aviator is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Passed CA Smog but still have a small problem boriswebs 86-95 Trucks & 4Runners 5 12-30-2006 09:49 AM
New member, small problem blank 95.5-2004 Tacomas & 96-2002 4Runners 4 08-18-2004 03:41 PM
Now that is small. Toddski Off Topic Talk 1 06-25-2004 12:36 PM
Am i too small? pinoy 95.5-2004 Tacomas & 96-2002 4Runners 24 02-24-2003 10:32 PM
Small problem prolax13 95.5-2004 Tacomas & 96-2002 4Runners 3 11-20-2002 07:11 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
