How do you check engine problems without a CEL?q
Old Sep 19, 2006 | 06:40 PM
igogusto's Avatar
I have had some stalling problems with my 4Runner after WOT. I have changed the Fuel Filter, cleaned the TB and MAF, changed the Spark Plugs, checked the hoses for cracks, changed the PCV Valve, cleaned the Air Filter, added a can of Seafoam to the Fuel Tank with 91 octane, all with no change to the problem.
I have yet to replace the IAC, as it scares me to tear this 4Runner apart. It looks as though I may need to install a new head gasket as I can see a small leak, but I am not losing oil.
Plug wires are next, since mine are originals on a 98 4Runner. 2WD, V6.
The only time that it threw a CEL is after I cleaned the TB and it was really dirty. I cleared the computer and the CEL has not come back.
Is there a way to diagnose engine/intake problems when you do not have a CEL light?????? Maybe a dumb question, but I am a newbie here, so forgive me.
Old Sep 19, 2006 | 09:19 PM
Elton's Avatar
have you got around to changeing the plug wires yet
Old Sep 19, 2006 | 09:26 PM
Localmotion's Avatar
ditto
I had the same problem under accel. Changed the wires and viola...all better
www.northridgetoyota.com
www.trdparts4u.com
talk to Strap22
Old Sep 19, 2006 | 11:30 PM
Elton's Avatar
if those prices are a little high can go with ngks from www.sparkplugs.com
Old Sep 20, 2006 | 03:44 AM
mt_goat's Avatar
OBDII should help.
Old Sep 20, 2006 | 04:11 AM
MTL_4runner's Avatar
Originally Posted by mt_goat
OBDII should help.
Ditto.....you need an OBD reader with allows you to see sensor outputs and engine parameters. There are a few out there but you need more than just a simple code reader. Search "auterra" and you should find a few models both PC and PDA based.
Few things I might try would be to replace your wires as suggested and second since you did mention a possible HG leak, you should probably do a compression test to ensure you don't have low compression in one of the cylinders. Finally you should take out the IAC and clean it because it sounds like a metering problem if the engine is stalling after WOT.
Old Sep 20, 2006 | 07:42 AM
igogusto's Avatar
The wires are my next step. Does anyone know if any of the local parts stores sell the NGK Wires? I can't seem to find them anywhere.
Do you guys suggest cleaning the IAC or replacing it? Do I need to buy gaskets? Do I need to get then from the stealership??
Thanks for the help!!!!
Old Sep 20, 2006 | 07:59 AM
Mikestang's Avatar
CELs are only triggered by problems that effect emmissions, they're not reflective of the entire operating conditions of a motor.
Old Sep 20, 2006 | 08:10 AM
jjrgr21's Avatar
Advance auto(kragen) has the OBD2 you can use, there in the parking lot. you just trade for your ID, plug it up, follow directions, take it back in, and they will print it out for you.
sonic concepts
Aug 16, 2025 03:13 PM
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
