How do you check engine problems without a CEL?q
I have had some stalling problems with my 4Runner after WOT. I have changed the Fuel Filter, cleaned the TB and MAF, changed the Spark Plugs, checked the hoses for cracks, changed the PCV Valve, cleaned the Air Filter, added a can of Seafoam to the Fuel Tank with 91 octane, all with no change to the problem.
I have yet to replace the IAC, as it scares me to tear this 4Runner apart. It looks as though I may need to install a new head gasket as I can see a small leak, but I am not losing oil.
Plug wires are next, since mine are originals on a 98 4Runner. 2WD, V6.
The only time that it threw a CEL is after I cleaned the TB and it was really dirty. I cleared the computer and the CEL has not come back.
Is there a way to diagnose engine/intake problems when you do not have a CEL light?????? Maybe a dumb question, but I am a newbie here, so forgive me.
ditto
I had the same problem under accel. Changed the wires and viola...all better
www.northridgetoyota.com
www.trdparts4u.com
talk to Strap22
www.trdparts4u.com
talk to Strap22
if those prices are a little high can go with ngks from www.sparkplugs.com
Ditto.....you need an OBD reader with allows you to see sensor outputs and engine parameters. There are a few out there but you need more than just a simple code reader. Search "auterra" and you should find a few models both PC and PDA based.
Few things I might try would be to replace your wires as suggested and second since you did mention a possible HG leak, you should probably do a compression test to ensure you don't have low compression in one of the cylinders. Finally you should take out the IAC and clean it because it sounds like a metering problem if the engine is stalling after WOT.
The wires are my next step. Does anyone know if any of the local parts stores sell the NGK Wires? I can't seem to find them anywhere.
Do you guys suggest cleaning the IAC or replacing it? Do I need to buy gaskets? Do I need to get then from the stealership??
Thanks for the help!!!!
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
