FearToys old rig
Old 07-24-2004, 07:29 PM
BruceTS's Avatar
FearToys old rig
I went on a 6 hour road trip up to NorCal to pick up FearToys old frame.....
His old rig;
He almost lost the rear spring, the pearch was almost completely broken out.....
This followed me home.....
Old 07-24-2004, 07:34 PM
shazaam's Avatar
Why did you purchase his old frame?
Old 07-24-2004, 07:55 PM
BruceTS's Avatar
To use as a jig, when I build my rear 4-link....
Old 07-24-2004, 07:56 PM
Good Times's Avatar
GOod to see that you've made it back Don't tell me you went up this morning to do a turn around!
btw, nice tinnnyyy tires!!!!! hehehehe
Old 07-24-2004, 08:01 PM
BruceTS's Avatar
left at 4am this morning, worked, then loaded, left Steve's place at 1pm and got home 7pm..... Yep, I didn't want to wear out my MTR's driving on this road trip......
Old 07-24-2004, 08:27 PM
Good Times's Avatar
yikes! 4am!!!! so should i expect a new 4 link system by say october?
Old 07-24-2004, 08:54 PM
FirstToy's Avatar
what happened to FearToy's truck? Does he have one anymore?
BruceTS, your truck actually looks great with the skinny tires!
Old 07-24-2004, 10:03 PM
Albuquerque Jim's Avatar
I know where you could score a rear axle housing to use in your build up...
Old 07-25-2004, 02:27 AM
BruceTS's Avatar
picked up that as well....
Old 07-25-2004, 07:11 PM
RobT2k's Avatar
Was that just due to wear and tear, or was it somehow fire related?
I thought he had a different rear susp setup that allowed for more flex, but it still used the factory spring perch? Maybe it was just the shock mounts that were custom/different.
Old 07-25-2004, 07:40 PM
BruceTS's Avatar
It was the spring pearch, with 2 tabs welded further inward from the stock shock location. I didn't see any fatigue to the right side, so he must have hit the left side quite hard on one of his trips, to start the fracture and then it just slowly progressed to the point where there's about 3" section holding it all together. I can't say what the exact cause was without having all the suspension parts to check clearances. My best guess is the added stress of having the shocks mounted in that location. I've seen a few other rigs that ran bilsteins and had their mounts break off. When you angle them inward, you have to use a stiffer shock to achieve similar results, by doing so you increase the loading on the mounts. This is one place that needs more bracing.
This is one of the reasons why I had to re-think my rear suspension, the stock mounts won't hold up after removing the panhard. Since I need to build stronger mount, I decided to do a more traditional triangulated 4-link design, with new mounting points. The frame will be used in setting up the links.
ladybugRC
458
08-21-2020 10:41 AM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
JookUpVandetti
09-30-2015 08:58 AM
Shagool22
09-28-2015 07:53 PM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: FearToys old rig
