Engine vibrates in gear when stopped
Old 07-03-2007, 11:22 AM
Shoretaco's Avatar
O.k. read through the other searches and found nothing really applied. My 2.7l auto Tacoma vibrates when you are stopped at a light or stop sign. It feels normal when in neutral or park. When you decellerate (spelling) you can feel it vibrate as you slow down. This just all of a sudden started there was no progression. Sometimes it is bad and sometimes barely noticeable.
Old 07-03-2007, 12:59 PM
mjwalfredo's Avatar
I read that this might be a result of a worn out rubber exhaust support. I purchased a new one for my 4Runner but I have yet to try it out because the old girl needs a new thermostat housing before I crank her up again. I'll post my results when I am done.
Old 07-03-2007, 02:08 PM
Caffeine's Avatar
how old are the plugs?
Old 07-03-2007, 03:50 PM
Shoretaco's Avatar
Less than 5k. Why would it shake only in gear? and its worse in reverse. It shakes pretty bad when you put it in gear and keep your foot on the brake.
Old 07-04-2007, 01:26 AM
Shoretaco's Avatar
Could it be the Torque converter since it only happens when trans is engaged?
Old 07-04-2007, 05:59 AM
Sickrunner's Avatar
i have a 97 4runner borla k&N cold air after i put my borla on i noticed the same thing when i pull up to a red light when in gear it almost seems like it is the exhaust shaking when i throw it into N or P the shaking stops.
Old 07-04-2007, 06:06 AM
Shoretaco's Avatar
Could be I just replaced my exhaust from the cat back so maybe that's it.
Old 07-04-2007, 06:30 AM
toyotaoffroad91's Avatar
+1 thats what did it for me
Old 07-04-2007, 08:38 AM
Skrillah's Avatar
I'd disagree, just rough idle. Try cleaning the MAF and the throttle body.
Old 07-04-2007, 01:36 PM
Shoretaco's Avatar
O.k problem solved, my neighbor got under car and I put it in gear. When I got my new exhaust they strapped the muffler hangers to the heatshield bolts. On a tacoma they are directly under the passenger seat and are aluminum. Pretty soft metal and not strong enought to hold a muffler. Any way the entire exhaust was moving(vibrating) from the headers back. I took out the hangars and guess what no vibrations. I fabbed up my own hangar and bolted it to the frame and its all gravy from there.
Old 07-04-2007, 03:36 PM
Ironmike4x4's Avatar
If I hadn't caught your thread earlier I would've suggested motor mounts. It's usually our number 1 culprit on GM stuff.
Old 07-04-2007, 07:10 PM
Skrillah's Avatar
Key word there "GM"! Haha
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
God's Bounty Hunter
07-08-2015 12:54 PM
Jnkml
07-06-2015 01:20 PM
mytruck
25
07-15-2002 04:28 AM
Quick Reply: Engine vibrates in gear when stopped
