Daystar 4th gen 1" front lift question
Old Nov 21, 2004 | 11:16 AM
03_4x4Runner's Avatar
On the daystar 1" front lift part #kto9117 does anyone know if the coil spring must be compressed and removed or does the spacer go on top of the strut assembly without compressing the spring?
Thnaks
Old Nov 21, 2004 | 11:24 AM
Good Times's Avatar
i think you will need to compress it and remove the top plate to replace the studs that go thru the top plate. i don't remember it exactly as i'm gettin old and forgetting the details but i do remember removing the top plate to replace the studs when i help install a daystar kit on a 4th gen.
good luck
Old Nov 21, 2004 | 11:28 AM
rngrchad's Avatar
spacers.
You will have to remove the coil/shock assembly, compress the coil, remove the top coil compression nut, and slide the spacer in. At least that's how I did my tuff country spacers.
Old Nov 21, 2004 | 12:00 PM
willymoe's Avatar
The Daystar 1" spacer will go on the top and require stud replacement. The 1.5" is a preload spacer.
Old Nov 21, 2004 | 05:34 PM
Good Times's Avatar
Btw are you planning on leveling the 4runner? if so, I think you'll want to get the full 2.5" front as the 1" won't do you much justice.
Talk to Biff (Victor) as I helped him install the 2.5" fronts.
Old Nov 22, 2004 | 12:54 PM
mac4runner's Avatar
I had the 1" Daystar spacer installed on my 2004 T4R last week and you definitely need to remover the coil/shock assembly, compress the coil, remove the top coil compression nut, and slide the spacer in. Personally I would stay away from anything larger than 1" as my current front and rear measurements are 35 1/2" and 35 1/4" respectively, so I'm slightly nose up. I wonder if NE will fab me a custom 1/2" rear spacer????
YMMV
Old Nov 22, 2004 | 12:58 PM
I raised the front 1" with a floor jack and you are right it really does not gain than much. I thought that if spacers would just slide in and the springs did not have to be compressed etc. it might be ok, but I will get a 2.5 lift because I need more clearance for rocks.
Thanks for all the replies.
Old Nov 22, 2004 | 03:26 PM
r0cky's Avatar
the only way you could do it without having to compress the coil would be to use a top out spacer. some people ask us to make them top out spacers alone because they don't want to deal with compressing the coil ... that's all fine and dandy, save for the fact that when you put a spacer on top of the top plate, you'll want longer studs, and to get longer studs, you have to compress the coil.
Old Nov 22, 2004 | 06:51 PM
fourunnabilly's Avatar
Guest
YMMV
hey bud, check your email...we have been waiting for an opportunity like this to happen for a long time, and have exactly what you need in stock and ready...thanks for the interest!!...custom work is our specialty! Thanks again.
Anthony
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
nick9455649
Sep 11, 2015 05:10 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Vargntucson
Jul 4, 2015 12:15 PM
