Old Mar 30, 2016, 10:42 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Interior Guides
Print Wikipost
Dash Lights
Old Jan 18, 2006 | 05:35 AM
Bigvick's Avatar
Dash Lights
The control panel for the heater, defrost, and AC has a light out in it. The temp. knob and the heat position knob light up but the fan control and the lever to switch from outside air to inside does not. What i'm wondering is there a bulb behind the panel that I can replace, or is it something that a whole assembly must be bought? This is in a '00 4runner.
Old Jan 18, 2006 | 03:01 PM
hupptoy's Avatar
Ihave replaced this bulb on my 99 4Runner and my 93 pickup in the past. There is a bulb that just pulled out after removing the face of the heater controls.
What I did:
I called the dealer and they told me they couldn't find a part number but could order a bulb @ $5 each! (bulb is tiny with 14V 1.4W written on it). I went to Autozone and asked them and their computer said it was a "74". WRONG, the 74 is too big! They did have a 2721 (although it is 2.1W instead of 1.4W) euro bulb that is the same size as the the Toyota bulb and is only $2 for 2. You will have to re-use the green sleeve from the old bulb (if yours has one).
Let me know if this is like yours.
hupptoy
Old Jan 18, 2006 | 03:29 PM
i_rifiyou's Avatar
when changing the bulb, take the knobs off the switches first, then the cup holder, lift the cup holder up then work it out....remember cup holder need to be lifted upward if you still want the cup holder
Old Jan 18, 2006 | 04:34 PM
hupptoy's Avatar
No cup holder in the dash of a 200 4Runner...but other info seems correct.
Old Jan 18, 2006 | 05:04 PM
964runner's Avatar
it is 2 74 bulbs. Ive changed mine on my 99 before, there a tight fit but they work
Old Jan 18, 2006 | 05:12 PM
i_rifiyou's Avatar
oh sorry about that, i have a 2nd gen and my light was a tight fit also, just a bit bigger and it had a green condom covering it
Old Jan 18, 2006 | 05:18 PM
Bob_98SR5's Avatar
look in the tech section and find any 3rd gen writeup on replacing stereos. you'll find the procedure to remove the panel in there w/ pics
bob
Old Jan 19, 2006 | 04:18 AM
Bigvick's Avatar
Thanks everybody! I try and get to it this weekend.
ashersullivan88yota
Jan 18, 2022 05:37 PM
ghostmoney
Jan 28, 2018 11:42 AM
AkitaDog
Sep 1, 2015 08:05 AM
ViperTT
Aug 14, 2015 05:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
