clutch pedal vibration
Old Jan 30, 2007 | 06:28 PM
johnw999's Avatar
I searched, but I couldn't find another post about my clutch problem. When I press the clutch pedal all the way down, it feels like it's not completely disengaging. The transmission shifts fine, but I can feel a vibration through the pedal. I have about 82k miles on the 4runner. Anyone know what is causing the vibration? Thanks
Old Jan 30, 2007 | 07:26 PM
rimpainter.com's Avatar
What year and what engine?
Old Jan 30, 2007 | 08:11 PM
johnw999's Avatar
It's a 2000 4runner. V6 engine
Old Jan 30, 2007 | 08:27 PM
Bigblock's Avatar
Some is normal,but How much vibration?
Old Jan 30, 2007 | 08:36 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
hows your clutch fluid? is there any freeplay in the pedal at the top of the stroke?
Old Jan 31, 2007 | 04:39 PM
johnw999's Avatar
I checked the clutch fluid, and it's fine. The vibration seems to be in tune with the engine RPM's. It's like I can feel the flywheel spinning. I did replace the clutch spring per the Unhappy thread, but I don't think that is related to this problem.
Old Jan 31, 2007 | 05:44 PM
My814x4's Avatar
Sounds like a bad pilot bearing
Old Feb 1, 2007 | 09:40 AM
Ironmike4x4's Avatar
From my GM book... sounds like flywheel is out of balance, the clutch components were misaligned when put in, flywheel is damaged or bent, missing flywheel bolts, or throwout bearing.
Old Feb 1, 2007 | 08:17 PM
shoveler's Avatar
After my clutch replacement (oem parts) I can feel a littel vibration when I shift at high (>4K) rpms. I always assumed that it was because I did not check the pressure plate engagement finger run out when I installed it. However it has run fine for 25K miles.
93toyoguy
3.4 Swaps
10
Sep 18, 2015 04:16 PM
Hugh_Mann
Sep 16, 2015 03:59 AM
Patrick1976
Sep 15, 2015 11:33 PM
Squigglez
Sep 4, 2015 07:33 AM
