auto tranny fluid question
hey guys just curious on what you guys use for auto tranny fluid i have an 02 tacoma 4x4 extra cab v6 auto and i just drain and fill every 15k miles or so with valvoline high mileage (83k miles on the truck)... never really had it brown just a dark red... what do you guys do... i have never flushed this truck nor do i think its ever been flushed
never removed a cooler line before all i do is just open the plug on the train pan. let it drain for a good hour or so. it usually drops about 5qts or so. its best to let it drain over night. but since i do this every 15k miles or so my tranny fluid from what i can tell is fairly clean.....
anything wrong with valvoline high mileage auto tranny fluid??
oh and when you take the pan off do you have to replace a seal?? and how do you clean off the screen?? never done it. i just drain and refill
I had a shop use the machine to get all the old fluid out and replaced w/ Amsoil synthetic. At the same time, we dropped the pan and cleaned the magnets. Now, I just drain and refill annually. The drain and refill is only a small percentage of the total fluid but since I've done this, the drained fluid is still red as can be.
The first time i did i disconnected the return line going into the tranny, drained the pan the refilled with 4 qrts redline D4, started her up and pumped out a gallon of fluid, shut her off and fill the pan with another 4 qrts. I did this about 4 times. Now every 30K i just drain whats in the pan. Right now ive got a mix of Redline D4 and Amsoil Universal ATF and to make filter changes eaiser i added a permacool remote filter kit between my stock and TRD cooler.
Toyota ATF is not that expensive, and it works great, I would stick with that or a high end synthetic if you want to spend more money. We have quite a few un-official writeups on doing a full flush yourself. See this thread to get you started.
can you explain your method in better detail.. interesting
It's the same method as in the link I posted in post #10... essentially. Although I don't recommend pumping it out a gallon at a time, though, because the pan only holds a little over a gallon, and you want to make sure you always have fluid at your pump's suction (which is the opening at the bottom of the filter). After I've drained, removed, cleaned, re-installed and re-filled the pan, I flush it approx 1 quart at a time to get the remaining fluid replaced. I also remove and clean the filter screen while the pan is off.
If you are considering going through the trouble of doing half... why not finish the job while everything is set up? It's only another 5 quarts, then you know that all your fluid is clean.
yeah true just dont like that fact that i would have to crank the truck a dozen or more times
Iceman4193
07-15-2015 04:48 PM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
