Any Trick to removing PVC
Old 12-23-2004, 05:48 PM
14thegipper's Avatar
Doing Seafoam and need a tip on what tool to use etc...
Thanks
Old 12-23-2004, 05:59 PM
Ducseven's Avatar
VERY GENTLY, I broke mine off at the neck the first time I tried it. Then I got to use the pliers to remove the broken part and installed a brand new one.
Now I just take off the hose and use that to suck in the Seafoam.
Old 12-23-2004, 08:16 PM
callmej75's Avatar
i remove the hose from the intake and put another gas line hose long enough to attach to the intake and pour it in that way and leave the pcv hose dangling. afte i get done i hook up the pcv hose but mine is brand new...last one shattered in chunks when i tried getting it off.
Old 12-23-2004, 09:18 PM
Where can I buy a new PVC - day before xmas?
Old 12-23-2004, 09:27 PM
Bob_98SR5's Avatar
hmmm...your local dealership?
bob
Old 12-24-2004, 12:35 AM
85TurboRunner's Avatar
you can find all the PVC you want at your local home depot, or lowes
Old 12-24-2004, 05:09 AM
callmej75's Avatar
auto parts store
Old 12-26-2004, 06:17 PM
Okay that was too easy, is there a gasket involed here or is it just plug-and-play?
Old 12-26-2004, 09:39 PM
4Crawler's Avatar
I found a smaller vacuum line worked better for my Seafoam treatment. I pulled the line that runs to the charcoal cannister (purge line). Its hooked up to the throttle body, and is nice and long. Even with the small 3mm line, I had to modulate the Seafoam intake to keep the engine running. You don't want to get too much of that stuff in there at one time, it can hydrolock the engine if it fills up a piston.
And that would be the PCV (Positive Crankcase Ventilation) valve.
Old 12-27-2004, 06:58 PM
Bigblock's Avatar
not just pcv ,theres an asortment of vac lines -brake vac,cruise,evap,a/c idle up,p/s idle up,vsv's,.........pcv's too damn hard to get to!
Old 12-27-2004, 07:13 PM
3car's Avatar
beat me to it.
06-01-2021 01:51 PM
okamikai
04-30-2018 10:19 PM
Jcrawl94
10
10-24-2015 04:34 PM
o2raybid
09-04-2015 12:45 PM
Oldmanleftear
09-01-2015 04:11 AM
Quick Reply: Any Trick to removing PVC
