Add Mod
Old 08-18-2004, 05:48 PM
lbb-1's Avatar
Add Mod
http://www.4x4wire.com/toyota/tech/add/
anyone do this what was the end result.
thanks
Old 08-18-2004, 06:23 PM
leebee's Avatar
im in the process of removing two sets of manual hubs from my donor vehicles, rebuilding them and doing this mod. i was hoping someone would have some input also. i guess we will have to check back every now and then.
lee
Old 08-18-2004, 06:30 PM
lbb-1's Avatar
going forward
will have it done by this sat.
hoping for feedback from authur.
later
Old 08-18-2004, 06:36 PM
Cebby's Avatar
I did this when I swapped in 5.29's. I had a separate pig set up with the gears. This housing had the non-add shafts attached, so we just installed them with the pig and plugged the vacuum lines.
The benefit? Simpler, so less parts to break.
Old 08-19-2004, 06:07 AM
lbb-1's Avatar
cool cool
Old 08-20-2004, 04:11 PM
leebee's Avatar
keep the add or remove it?
hey cebby!
what would be the benefit of removing the add system altogether? would it operate like my old 86 runner? it was a 4 banger 5 spd with manual hubs. what would i gain by keeping the add system? if all it is is shift on the fly capability, then ill dump it. i usually shift the tc when im stopped, using it on the trails i would just lock the hubs before hand and unlock when im done. same thing for winter driving, lock the hubs and shift the tc when needed. hope this is making some sense, thanks for any input.
lee
Old 08-21-2004, 04:19 AM
Cebby's Avatar
Someone correct or validate me on this. Here's my take...
ADD diff tubes (with actuator) and drive plates = Standard diff tubes (no actuator) and manual hubs.
The shift on the fly is a function of the T-case. The "convenience" of ADD is that you never have get out to lock your hubs. The penalty for this is CV wear since they are always turning with the ADD setup (not under load though until you shift into 4WD)
Adding manual hubs to reduce CV wear makes having ADD a redundancy. Basically you have two disconnection points from the driveline with ADD and manual hubs. You only need one.
Old 08-21-2004, 08:29 AM
leebee's Avatar
im liking this!
hey cebby!
thats what im looking for! just got in from work and figured id better check and see if anyone had commented on this. unless anyone else replies differently, the add system will be history. thank you for shedding some light on this, i was beginning to wonder if i would ever get an answer one way or the other. anyone able to rebut? willing to look at all suggestions before making a final decision.
lee
TheBFA
02-15-2020 06:55 AM
Obmi
10-04-2015 11:30 AM
JookUpVandetti
09-30-2015 08:58 AM
oldblue
09-28-2015 04:07 PM
Project90
09-24-2015 11:40 PM
Quick Reply: Add Mod
