clutches and flywheel help needed
Ok so I am getting ready to pull the auto and put the manual 5 speed in. I picked up a 5 speed from 3.4 from a member here last week. That will give me the driver's side clutch operation that I need to keep the stock downpipe and crossover and pass smog again.
SO in review, I will have a 97 3.4 and a 95.5 5 speed and ECM.
My question is on the clutch and flywheel. I do not think that I will stay with the 3.4 r150 so i really do not want to put any, or at least as little as possible, in making in work. The guy I got the tranny from, gave me a clutch set, less the bearings. I dont mind the bearings but I realy so not want to buy a flywheel for a temp use.
I have all the 3.0 r150 flywheel, clutch, everything that was in great shape when it was pulled. Any chance that I can use the 3.0 stuff on the 3.4 tranny? I also have the old 3.0 starter to match the ring gear.
Any advice on the cheapest way to do this is?
ya but he is using the 3.0 r150. I am wondering if with my using the 3.4 tranny the 3.0 stuff will still work.
I think that i may just buy new 3.4 clutch and flywheel since it will work with both trannys anyway. It wouldnt be a total waste regardless of which tranny i end up using in the final form and from what i read the 3.4 clutch and flywheel setup is "better" anyway since its larger.
Interesting. I have been considering a 5 speed swap. So is the 3.4 5 speed transfer case a bolt in to the 3.0 drive shafts, or is the tcase on the opposite side?
I have a 3.4 starter and a manual cross member sitting in the garage. Dont know whether to sell or keep picking up parts as and when needed for the complete swap.
IIRC both of these tranmissions are interchangable with each other, other that the transfer case drop. Both starters (3.0 and 3.4) will work with the 3.0 trans and the 3.0 clutch set-up. IIRC the only difference between the 3.0 and 3.4 flywheel and clutch assy. is the diameter of the clutch disc and pressure plate (hence a larger bolt circle on the 3.4).
The 3.0 clutch set-up seems to work well with the stock 3.4 hp (non-supercharged), but you do have to use the 3.0 flywheel. If you choose to use the 3.4 clutch, you will have to use a 3.4 flywheel.
I am looking for used 3.4 flywheels to then take over to Marlin and have them resurface it. Can anyone count the teeth on their 3.4 flywheelso i know which one i need please?
Napa shows a 120 tooth version and a 115. I would assume the 115 is 4cyl but want to make sure before i buy a used one and have it be wrong.
Marlin make a Taco clutch kit, so i will just buy that i guess but they offer no flywheels for 3.4's.
Thanks
Jason
Thanks
Jason
it's a flywheel for crying out loud. it's not like it needs to be an ultra light racing flywheel right? check with you local wrecking yards, i'm sure you can get one on the cheap.
nope. doesnt need to be anything fancy. Anyone have a tooth count for their 3.4 flywheel laying around?
Just dont trust Autozone parts all that much.
20 tooth
[EDIT] just noticed I put 20 tooth in subject ignore it is 120 tooth
Hey thanks for confirming that for me. Any chance that there is a part number on there?
I went to Napa and they have a new one; no core for $100. Has a huge MADE IN CHINA on it. Anything that large that spins that fast and is made in China makes me nervous.
Autozone wants 75 for a core that I dont have.
I'll probably just junkyard one so that I have a factory Toyota and take it over to Marlin and have them do their magic to it.
Jeff
Oh, and my understanding of the starter differences are that you use the starter for the flywheel. (i.e 3.0 starter use 3.0 flywheel) when you use the 3.4 starter with older R150 passenger side clutch slave bellhousing you have to drill out the threads on one of the mounting holes of the starter to mount it. You shouldn't have this problem with your newer 3.4 trans since it should have the clutch slave on the driver side.
Hate to bump a old thread. But I'm doing a budget 3.4 swap. And my 3.0 clutch/flywheel/pressure plate/through out, all have low miles (under 5k)
I've read that "mechaniman" was able to reuse all that stuff. Anyone else? What starter was used?
Thanks
MK
Thanks
MK
clutch,etc.
Read posts#6 and 15 below. They explain it all.
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
