| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Trial Gear ifs eliminater kit S.A.S help 80s to 81 front solid axle
#2 (permalink) |
Super Moderator-Sponsoring Member
Staff
Main website page says 79-85 SFA.
Install instructions say 81 and up. Only thing I know that is different is the axle gusseting. Never personally used anything but an 84/85 axle.
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#3 (permalink) |
should just be the gusset.. u should be good to go
__________________
current: 1986 4Runner, Rebuilt 22RE with engnbldr HP head, cam'd, battery/intake swap, SASed, 5.29s, detroit rear, 35in MTRs, trussed and armored axles, marlin HD clutch, soon to be dual cased, TG rear bumper, Best mod todate CHROME METAL SR5 DOOR HANDLES, thats whats up RIP: 1985 Standard Cab SR5 pickup, add-a-leafs and shackels, 33" BFGs, it died a horrible death (50mph roll over) DD: 2006 Scion Tc w/TRD Supercharge and TRD stainless cat-back exhaust |
#4 (permalink) |
i agree with above
__________________
1988sr5 4.3v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits 1972 stepside jimmy d44/d70 425hp 1995 green range rover |
#5 (permalink) |
ok so the pumpkin would be in the middle and i cant use the upgrade armor the kit came with ?
#6 (permalink) |
Staff
No, the gusseting on the bottom of the earlier year model axles is shorter or there is none. The pumpkin is going to be on the passenger side. Diff armor should work. I don't know of anything that won't work with that axle with that kit.
__________________
#7 (permalink) |
Some people actually prefer the older style axles (79-81) with no gusset on the bottom...
There's about a quarter to half inch extra ground clearance under the driver side axle tube!
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#8 (permalink) |
OK well I found a 1985 solid front axle i think im just going to get that for $300 bucks is that a good deal ? its newer so i hope its in better condition. And wabfab I might buy some 5.29 gears from you guys do they hold up well ?
#9 (permalink) |
5.29 gears hold up great, my roomate has been running them on his SAS 4runner for the last 4 years with aussies and hasnt had a problem yet, at first the small pinion will through off but the strength is there
#10 (permalink) |
sweet I might buy some. I have the axle all rebuilt and sanded just needs welded which I had to repair my welder because its been many years sense ive used it.
#11 (permalink) |
The 79-80 axles have a smaller hub assembly, lug nut base diameter, and rotor design than the 81-85s. So, the reason why TG say they won't work is because their new rotors won't work with the older hub assembly on the 79-80 axles. Lug nuts won't press into the back of the hub/rotor. Although, you could just swap in a later model hub assembly.
__________________
Scotty http://www.addictedoffroad.com/ 970-420-4198 Toyota Winch bumpers on SALE! |
#12 (permalink) |
I second what ScottyC has to say. If you found an 85 though you're good to go. I would say $300 is fair. I don't know about your neck of the woods but those axles are getting hard to find around here. Prices are going up.
__________________
1995 Toyota PU SR5. 2000 3.4l V6 and a few other mods. my album: http://www.yotatech.com/album.php?albumid=101 my SAS: http://picasaweb.google.com/areinhol...eat=directlink www.overlandcanada.ca www.alltracwagon.net |
#13 (permalink) |
the rotors for the 79 and 80 pickups mount with with 6 bolts not wheel studs and 2 bolts. 79 & 80 axles will need an 81 or so fj40 rotor to get a vented rotor. trail gear doesn't sell a 6 hole rotor.
__________________
1985 X-cab pickup. stock 1988 Trail Truck. SAS, Dual Cases, FROR Twin stick, 30 Spline Longs & IFS Hub Gears, Exoed, Aluminum Trail-Ready Beadlocks, 37" Boggers, and Extreme Rock Rash. 2008 Camry LE. |
#14 (permalink) |
hey guys i got a question i have a 1998 toyota 4runner 2wd i have got some of my 4wd conversion parts but i was wondering these kits you can buy to convert you 4runner to sas. the ones form marlin and trail gear say there for a ---- to a 1995 would they work one my 98 or do i need to get it from somewhere else and if so where from.
| Tags |
| gear, ifstrial, s.a.s swamp axle ifs |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| IFS hubs & calipers on a (79-85) solid front axle | joebruva25 | Offroad Tech | 2 | 12-25-2006 04:20 PM |
| FS: 85 rebuilt solid front axle with 5.29's and ARB with All Pro Conversion Kit | martin | The Classifieds GraveYard | 5 | 11-20-2006 07:06 PM |
| IFS or Solid front axle? | sorny | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 07-13-2005 07:11 AM |
