YeloSub7's 1990 4Runner Build-Up Thread
Old Mar 10, 2008 | 06:37 PM
YeloSub7's Avatar
Well I might as well start this thread now...
SAS and RLS on my '90 4Runner 22re 5speed
3" TG front SAS
4" TG rear leaf swap
4.88 thirds from Mattb124 (thanks mat!)
Detroit Tru-Trac front
Precision Gear Limited Slip rear
33x12.5x15 GT Radial M/T
15x8 steelies (3.5" backspacing)
My truck as it sits right now, stock on 31's
'85 4runner front axle...
33's
my freshly painted steelies...
now just waiting for the TG delivery
Old Mar 10, 2008 | 06:39 PM
PoleVaulter95's Avatar
i cant wait for this. I've been wanting to sas but most i see are up to 35's. and i think 33's will be great. looking forward to measurement heights. Subscribed.
Old Mar 10, 2008 | 06:43 PM
UKMyers's Avatar
Look up Mark P he has a sweet set up on 33's.
Old Mar 10, 2008 | 06:47 PM
YeloSub7's Avatar
Ya I had a '94 4runner on 33's with ifs lift and like the height, even though this will actually be more like 5in front what I've heard. It is going to be my daily also for about a couple years, so wanna keep it low for now. Don't drive much or far anyways. Will go bigger later on (of course), but for now we'll see how this turns out...
thanks UKMyers. you got a sweet setup too. that last pic of your 4runner sittin on a trailer behind a new tacoma is depressiong. (but in a good way)
Old Mar 10, 2008 | 06:48 PM
well i hope its not too big, because my 4runner is my daily driver. lol
Old Mar 10, 2008 | 06:53 PM
YeloSub7's Avatar
like I said I don't drive much anyways...
Old Mar 10, 2008 | 06:55 PM
UKMyers's Avatar
What do ya mean?
Old Mar 10, 2008 | 07:04 PM
its a beautiful sight. a 4runner fully built on a trailer pulled by a new toyota is depressing to anyone who cant afford it.
Old Mar 10, 2008 | 07:11 PM
Marc P's Avatar
Sounds like a nice build. I think the 3inch springs will not work well for you...especially if you ever put a winch up front.
I see you have a 22RE, so it may be ok for a while. I just bought some 5inch springs because my 4in ones have gone flat with the addition of a bumper and winch.
Old Mar 10, 2008 | 07:17 PM
Marc P you are saying that a 3vze bumper and winch will be too much for the 3inch springs? do you feel with the larger springs your tires will appear too small?
Old Mar 10, 2008 | 07:32 PM
Marc P's Avatar
Not really, they will settle. If it is real bad I can remove a leaf also.
Here is how mine looks now...I figure the 5inch springs will pick up the front about 2 inches
Old Mar 10, 2008 | 07:43 PM
yotaman's Avatar
Man that truck is tall right now and you plan to go taller?
I had 4" TG springs up front with 35" and I think my truck is TALLLL. I'm moving up to 38"-40" Iroks and 4+" wider axles and plan to lower my truck at the same time. Some will happen of course.
Old Mar 10, 2008 | 07:51 PM
YeloSub7's Avatar
I want to stick with the 33's though, and I won't be able to afford a bumper and winch anytime soon anyways
But seriously? IMO I think your rig is too tall with the 33's, at least for what I want. But it is something to consider, thanks...
Old Mar 10, 2008 | 08:26 PM
Marc P's Avatar
That pic is before I added the 80lb winch. I also have nothing in the back. I usually carry my tools and recovery gear
Mine is not very tall....just that pic makes it look big
this may give a better perspective
Old Mar 10, 2008 | 09:02 PM
4RunnerKid's Avatar
SAS 4Runners all look tall. it's just the nature of an SUV. being as narrow as Toyotas are doesn't help either. the TG 3" springs usually run tall, from what i've seen. i've also read that they have the second highest spring rate of all the TG springs too (5" HDs are first). if you really want it to be low get a set of springs made, go the JY route, or pull some leaves. pulling leaves is going to kill your spring rate, custom springs are going to be costly, and JY springs are kind of a trial and error thing.
i've found that the 5" HDs are perfect for my rig. they sit a little taller than i'd like to be (26" frame height on 35s) but the spring rate is perfect (i like to pre-run/go-fast a little too), shackle angle is perfect, and they hold up to the V6 weight and my heavy bumper.
whatever you do, good luck. it's going to be tough to get the best of both worlds, but i'm sure with enough research and tinkering you'll find something. maybe look into a stock front spring with some leaves added?
Old Mar 10, 2008 | 10:05 PM
YeloSub7's Avatar
Thanks for the input guys! All we can do now is wait for the TG shipment and see how this baby turns out
Old Mar 13, 2008 | 08:06 PM
YeloSub7's Avatar
The delivery came! Hopefully get a good start on it this weekend! Will post some pics as things happen...
Old Mar 13, 2008 | 08:11 PM
Good luck cant wait to watch this unfold. be sure to take alot of pictures (and as im sure ive said measurements!).
Old Mar 16, 2008 | 09:06 PM
YeloSub7's Avatar
here is a bit of progress I made over the weekend...
rebuilt knuckles
axle cut and cleaned up
new rotors
my buddy helping me with some welding
primed axle
painted axle!!! (sorry pic taken at night)
hopefully will get the SAS mostly done tomorrow...
