YeloSub7's 1990 4Runner Build-Up Thread
Old Mar 16, 2008 | 10:06 PM
fillsrunner4's Avatar
You should pick up some gussets for the knuckles. I recommend them highly and nows the best time during the swap to put them in. Just a suggestion but other than that its looking good
Old Mar 17, 2008 | 12:53 PM
4RunnerKid's Avatar
x2
those knuckle gussets are key.
Old Mar 17, 2008 | 09:28 PM
georgedog's Avatar
Question 6 speed tranny
Did I read correctly that UK Meyers is putting a 6 speed transmission in to his 2006 Tacoma? This is my first response. I am looking for a thread or site that has information to help me transform my 2003 tacoma to be more fuel efficient Thanks Georgedog.
Old Mar 18, 2008 | 08:48 PM
Many ways to do so but first welcome and second search some. I dont know if its been done so I wont really say to much about that tranny swap but i dont really see that as a mod to take care of fuel efficiency. Intake and exhaust first then maybe a few other things.
x2
And when the axle is apart or out is the best time of all to add them. take it form 4runnerkid cause he used to not have them now he does and theres plenty of reasons why too have them and why he added them second time around
Old Mar 19, 2008 | 01:09 PM
  #25
YeloSub7's Avatar
sounds good guys... thanks
Originally Posted by 4RunnerKid
x2
Old Mar 19, 2008 | 04:23 PM
  #26
YeloSub7's Avatar
got the front hanger and shackle sleeves welded
Old Mar 19, 2008 | 04:31 PM
  #27
YeloSub7's Avatar
NO MORE IFS
and some paint
how it sits waiting for more grinding
Old Mar 19, 2008 | 07:53 PM
  #28
Wheelingnoob's Avatar
Looks good, what happend on the sleve welding?
Jeremy
Old Mar 19, 2008 | 09:04 PM
  #29
YeloSub7's Avatar
Jeremy
Old Mar 19, 2008 | 11:10 PM
  #30
UKMyers's Avatar
Please tell me you didn't permanantly weld on the hanger before you ever sat the trucks weight on the springs and looked at the shackle angle..... Hopefully those springs work out for you. My spring rate sucks with the 4" ones. I pound the crap out of my bumpstops with my V6 and winch up front.
Old Mar 20, 2008 | 03:23 PM
  #31
Good idea to check the shackle angle before fulluy welding on the front hanger. I need ot rememeber that when I start welding my stuff on.
The 3" TG springs are the 2nd highest spring rate springs they sell only just behind the 5" HD's. I have the same kit going on my truck (4runner, v6, winch and bumper) after talking to TG they advised that the 3" would be fine as long as I swapped on a 2wd oil pan. I guess I will find out soon enough. I do not want a huge truck as mine will mainly be for expadition and my tires will never be over 35's right now I'm at 33's and do not see my self going up anytime soon.
I have wheeled with a guy with V6 winch and bumper, with his 4" TG springs the truck saged badly in a few months. He has since swapped to 3" and has had no problem since in 2 years of use.
I'm really looking forward to seeing your truck on the ground.
Jeremy
Old Mar 20, 2008 | 03:41 PM
  #32
Originally Posted by YeloSub7
It looks like you welded on a plate above the guset and the welds in the first pic looked a bit off to me. Sorry for the critique did not mean anything bad by it.
Jeremy
Old Mar 21, 2008 | 10:06 AM
  #33
YeloSub7's Avatar
Jeremy
Ah, there was some bracket in the way of where we needed to torch the holes for those shackle sleeves. When we cut that off, there was a hole. This created for a very thin wall between the existing hole and where the shackle sleeves went. Hence the extra bracing
Old Mar 21, 2008 | 06:27 PM
  #34
Ahh ok that makes sence, looking froward to seeing it on the ground.
Jeremy
Old Mar 21, 2008 | 06:41 PM
  #35
JGrund85's Avatar
Looking good man! I wish I could have had the time and know how to do my own SAS!
Old Mar 21, 2008 | 06:53 PM
  #36
PITBULL2888's Avatar
what is sas?
Old Mar 21, 2008 | 07:14 PM
  #37
yotaman's Avatar
Originally Posted by PITBULL2888
what is sas?
Solid Axle Swap!
Old Mar 21, 2008 | 07:42 PM
  #38
what is sas?
Im still trying to figure that out myself Welcome and if your serious search
Old Mar 21, 2008 | 08:56 PM
  #39
i'm sorry im new to 4x4 trucks i thought it was a type of suspension
Old Mar 21, 2008 | 09:14 PM
  #40
YeloSub7's Avatar
